CAC-1517 The Club 3D is a DisplayPort™ signal converter. The USB 3.1 Type C Cable to DisplayPort 1.2 UHD Adapter is the easiest solution for connecting your USB 3.1 Type C source device featuring DisplayPort⢠Alternate Mode to a DisplayPort™ 1.2 enabled (Ultra) High Definition Monitor, Television or Projector. Powered by the USB Type C port, the adapter requires no external power and is ideal for use with the latest notebooks / MacBook (pro) and Tablets.
Supports up to 4K UHD Resolution at 60Hz and AMD FreeSync.
The USB 3.1 Type C Cable to DisplayPort™ 1.2 UHD Adapter supports (U)HD resolutions up to 4K UHD @ 60Hz for a clear, sharp picture. The support for 60 frames per second provides exceptionally smooth video. Use the adapter to play games, view video or browse the internet from your USB 3.1 Type-C enabled device on a (Ultra) High Resolution monitor or TV. Supporting up to 8 channels of audio, the adapter provides high-definition digital audio and video. Does not support Dual Mode DisplayPort™ (DP++)
The USB 3.1 Type C Cable to DisplayPort™ 1.2 UHD Adapter supports all USB 3.1 Type-C devices with DisplayPort™ ALT mode and operating systems, including Apple OS X, Windows 7, 8.1 and 10 and Google Chrome OS.
Please refer to your device's user manual to confirm the specification and
functionality of the USB-C port.
Model |
Product Name: USB 3.1 Type C Cable to DisplayPort™ 1.2 UHD Adapter |
Product Series: Cable |
Weight: 47 gr |
Cable length: 1200 mm |
Item Code: CAC-1517 |
EAN Code: 8719214470616 |
UPC Code: 841615100798 |
Features |
• Reversible USB 3.1 Type C connector |
• Compliant to VESA DisplayPort™ Alt Mode Standard |
• Supports full link training and no link training |
• Supports (U)HD resolutions up to 3840 x 2160p @ 60Hz |
• Supports 3D Video formats up to 1080p @ 120Hz |
• Compatibel with Thunderbolt 3 |
• Powered by USB Port (no external power needed) |
Connector 1: |
USB 3.1 Type C Male |
Connector 2: |
DisplayPort™ 1.2 Male |
Compatibility |
Supports AMD HD 6xxx, Nvidia® Maxwell and Intel® HD/ Iris™ graphics solutions and newer. |
Requires DisplayPort™ Alt Mode support from the source system. |
Operating Systems |
Microsoft Windows |
Apple OS X |
Google Chrome OS |
In the Box |
CAC-1517 USB 3.1 Type C Cable to DisplayPort™ 1.2 UHD Adapter |
Other Info |
Box size 14.5cm x 14.5cm x 4.5cm |
