Mini DisplayPort to DVI-D SL Active Adapter
CAC-1152 The Club 3D CAC-1152 is an Active DVI-D signal converter. The Mini DisplayPort™ to DVI-D Adapter is the easiest solution for connecting your Mini DisplayPort™ enabled Desktop or Laptop to a DVI-D enabled High Definition Television, Monitor or Projector.
The adapter works with AMD, Intel® and Nvidia® graphics solutions and supports a maximum resolution of 1920x1200p @ 60Hz. Simply connect the Mini DisplayPort™ (male) end of the connector to your computer and plug your existing DVI-D cable from the display into the DVI (female) adapter.
Setup requires no software installation. The circuitry built into the adapter seamlessly converts the Mini DisplayPort™ video signal into a DVI Digital video signal. Supports AMD Eyefinity and other Multi Monitor configurations.
This professional grade adapter-cable is ceritfied by Vesa.
Please note that this adapter is for digital signals only and will not fit analog DVI-I ports.
Model: |
Product Name: Mini DisplayPort to DVI-D Single Link Active Adapter |
Product Series: Adapters |
Itemcode: CAC-1152 |
EAN code: 8717249408826 |
UPC code: 854365005176 |
• Compliant to DisplayPort™ 1.1 Specification |
• Compliant to DVI-D specification |
• Supports resolutions up to WUXGA 1920x1200p @ 60Hz |
• Supports High Definition resolutions up to Full HD 1080p @60Hz |
• Supports AMD Eyefinity |
• No external power needed |
• Supports AMD, Nvidia® and Intel® graphics solutions |
• Vesa ceritfied |
Please note that this adapter is for digital signals only and will not fit an analog DVI port. |
Connector 1: |
Mini DisplayPort™ Male |
Connector 2: |
DVI-D Single Link Female |
Windows 10, Apple OS X |
• Boxsize:240 x 60 x 35mm. |
• Cable: 200 x 44 x 18mm. |
• Weight: 56 gr. |
• Made in China |
Club 3D Mini DisplayPort to DVI-D Single Link Active Adapter |
