DisplayPort to DVI-D SL Active Adapter
CAC-1052 The Club 3D is an Active DVI-D signal converter. The DisplayPort™ to DVI-D Adapter is the easiest solution for connecting your DisplayPort™ enabled Desktop or Laptop to a DVI-D enabled High Definition Television, Monitor or Projector.
The adapter works with AMD, Intel® and Nvidia® graphics solutions and supports a maximum resolution of 1920x1200p @ 60Hz. Simply connect the DisplayPort™ (male) end of the connector to your computer and plug your existing DVI-D cable from the display into the DVI (female) adapter.
Setup requires no software installation. The circuitry built into the adapter seamlessly converts the DisplayPort™ video signal into a DVI Digital video signal. Supports AMD Eyefinity and other Multi Monitor configurations. Please note that this adapter is for digital signals only and will not fit analog DVI ports.
This professional grade adapter-cable is ceritfied by Vesa
Model: |
Product Name: DisplayPort to DVI-D Single Link Active Adapter |
Product Series: Adapters |
Itemcode: CAC-1052 |
EAN code: 8717249408833 |
UPC code: 854365005107 |
• Compliant to DisplayPort™ 1.1 Specification |
• Compliant to DVI-D specification |
• Supports resolutions up to WUXGA 1920x1200p @ 60Hz |
• Supports High Definition resolutions up to Full HD 1080p @60Hz |
• Supports AMD Eyefinity |
• No external power needed |
• Supports AMD, Nvidia® and Intel® graphics solutions |
• Vesa ceritfied |
Please note that this adapter is for digital signals only and will not fit an analog DVI port. |
Connector 1: |
DisplayPort™ Male |
Connector 2: |
DVI-D Single Link Female |
Windows 10, Apple OS X |
• Boxsize:240 x 60 x 35mm. |
• Cable: 200 x 44 x 18mm. |
• Weight: 56 gr. |
• Made in China |
Club 3D DisplayPort to DVI-D Single Link Active Adapter |
