USB 3.1 Hub 4-Port with Power Adapter
CSV-1431 The Club 3D USB 3.1 Gen 1 Hub 4-Port with Power Adapter is designed in a stylish and sturdy aluminum casing and is very slim which makes it easy to carry around.
The CSV-1431 allows you simultaneous access to 4 x USB 3.1 Gen1 ports from just one single USB 3.1 Gen 1 uplink. The CSV-1431 comes standard with a Power Adapter so that the user can connect even the most power-hungry USB devices like External HDD Drives, Digital Camera, Mobile Phones etc.
The 4 USB ports are all USB Type A and USB 3.1 Gen 1 compliant and downward compatible to USB 2.0 standard, but this will have influence on the performance.
Model |
Product Name: Club 3D USB 3.1 Gen 1 Hub 4-Port with Power Adapter |
Product Series: Docking Station |
Weight: 70gr |
Cable length: 100 mm |
Item Code: CSV-1431 |
EAN Code: 8719214470128 |
UPC Code: 841615100224 |
Interface |
Uplink: USB 3.1 Gen 1 Male x1 |
Voltage |
USB bus powered 3.3V/500mA |
Power Adpater 5V/2.5A or 5V/4A |
Output Configuration |
USB 3.1 Gen 1 x 4 female |
In the package |
Slim design with Aluminum Casing |
Support auto switching between AC-power and USB-bus-power mode |
Switching power adapter included; Output: DC 5V/2.5A or 5V/4A |
Support Battery Charge 1.2 Fast Charge Function and Apple Charging |
Compatible with USB 3.1 Gen 1 standard and downwards compatible with USB 2.0 standard |
Support the following speed data rate as follows; Low-speed (1.5 Mbps) / Full-speed (12 Mbps) / High-speed (480 Mbps) / Super-speed (5 Gbps ) It works with Windows and Mac OS X |
The minimum requirements for the pc are: |
PC / Laptop / Tablet with free USB 3.1 Gen 1 Port |
Supported Operating Systems: |
- SPECIFICATION SHEET_CSV-1431_EN.pdf
- SPECIFICATION SHEET_CSV-1431_DE.pdf
- SPECIFICATION SHEET_CSV-1431_ES.pdf
