MST Hub USB 3.1 Gen1 Type C to DisplayPort™ 1.2 Dual Monitor
CSV-1545- Displays have always been a key part of the PC experience. PC Gamers want a more immersive experience and Professionals seek more desktop space to run apps side by side and increase their productivity. The easiest solution is to add multiple Monitors to an existing Laptop or Desktop PC.
The Club 3D MST Hub USB 3.1 Gen1 Type C to DisplayPort™ 1.2 Dual Monitor is an invaluable tool for gaming, multitasking, or simply for the fun of it. This product enables that multiple individual video signals can be sent through a single USB 3.1 Gen1 Type C output with Displayport Alt Mode support, and sends those to the connected Screens.
Note: When using an video output with DisplayPort™ (Alt Mode) 1.1 support, the MST hub will act as a splitter, automatically mirroring your video source across the displays.
AMD Eyefinity™
Enjoy the ultimate immersive gaming experience. With AMD EYEFINITY technology, you can connect up to 6 displays to an individual graphics card by using Club 3D MST Hub(s). Each monitor can have an independent video signal or you can create a Single Large Surface (SLS).
Add on
Ultimate in Color and Image Quality
Ideal for photography, graphic design, media creation and other color-critical applications. The Club 3D MST Hub USB Type C to DisplayPort™ 1.2 Dual Monitor supports 6 / 8 / 10 / 12 bit color depth.
Dual Mode DisplayPort™
The Club 3D MST Hub USB Gen1 Type C to DisplayPort™ 1.2 Dual Monitor supports Dual Mode DisplayPort™ (DP++) which allows the use of DVI or HDMI™ Monitors via passive adapters. With multiple Monitors, games become more immersive, workstations become more productive.
Model |
Product Name: Club3D MST Hub USB 3.1 Gen1 Type C to DisplayPort™ 1.2 Dual Monitor |
Item Code: CSV-1545 |
EAN Code: 8719214470562 |
UPC code: 841615100743 |
Interface |
USB 3.1 Gen1 Type C to Displayport Hub for Dual Monitor |
Voltage |
Powered thru USB Type C (5.0V @ 220mA max), no external power adapter required. |
Output Configuration |
DisplayPort 1.2a x 2 |
In the package |
Club 3D MST Hub USB 3.1 Gen1 Type C to DisplayPort™ 1.2 Dual Monitor |
Instruction manual |
For the CSV-1545 your system does require to support Displayport ALternate Mode for USB Type C output. |
DisplayPort 1.2a supports up to twice the bandwidth of DisplayPort 1.1a (HBR). High Bit-rate 2 (HBR2) provides up to 5.4Gbps/lane of bandwidth, or up to 21.6Gbps in a full four-lane configuration. This lends itself very well to many applications that require ultra-high bandwidth. |
Supported Resolutions |
MST shares 21.6 Gbps across all attached displays. Higher resolutions can restrict the available bandwidth with the remaining ports, please see our guideline below for determining an ideal resolution for your setup. |
Note: Some Notebooks/Tablets/Mini PC's have Integrated Graphics Chips which do not support more than 3 screens in total. Please consult with your device specifications for further information. |
Average resolution bandwidth allocation: |
1920x1080 (High-definition 1080p) @60hz - 22% |
1920x1200 @60hz - 30% |
2560x1440 @60hz - 35% |
2560x1600 @60hz - 38% |
3840 x 2160 (Ultra HD 4K) @30hz - 38% |
3840 x 2160 (Ultra HD 4K) @60hz - 72% |
Note: Exceeding 100% will reduce functionality. |
With DisplayPort™ Native resolutions up to FHD (4K x 2K) @60Hz, 24bpp but limited by DP banwidth) |
Operating Systems: |
• Windows 10, 8.1, 7 |
- SPECIFICATION SHEET CSV-1545_EN.pdf
- SPECIFICATION SHEET CSV-1545_DE.pdf
- HOW_2_CSV-1545-EN-DEF_AMAZ.pdf
- CSV-1545-MANUAL.pdf
