HDMI 1.4 to VGA Adapter
CAC-1301 This Club3D Adapter is an active HDMI™ 1.4 to VGA signal converter. It accepts HDMI™ input from HDMI™ 1.4 enabled Desktop or Laptop and converts to a legacy analog VGA output allowing the use of analog VGA Televisions, Monitors and Projectors. The adapter offers hassle free plug and play functionality and is powered by the HDMI™output.
The HDMI™ 1.4 interface in the adapter consists of two main lanes for HDMI™ data, AUX channel, HPD signal and power. The VGA output is compliant to VSIS standard and supports up to WUXGA RB timings.
The adapter works with AMD, Nvidia and Intel Graphic Solutions and supports AMD Eyefinity™.
Model: |
Product Name: HDMI™ 1.4 to VGA Active Adapter |
Product Series: Accessories |
Itemcode: CAC-1301 |
EAN code: 8719214470654 |
UPC code: 841615100835 |
HDMI™ 1.4 Male |
VGA Female |
• Supports HDMI™ 1.4 input specs |
• Triple 8-bit DAC (Digital-to-Analog Converter) with clock up to 210-MHz |
• Powered by the HDMI™ output |
• Compliant with the VESA VSIS |
• Real-time Hot plug detection |
• Support for multi-monitor setups and AMD Eyefinity™ |
• Compatible with AMD, Nvidia and Intel Graphics solutions |
• HDCP support is not possibble with Analog / VGA Displays |
• DisplayPort 1.1a compliant receiver offering 5.4Gbps bandwidth over 2 lanes |
• Integrated tripler 10-bit,162MHz video DAC for analog VGA signal output |
