DisplayPort 1.4 HBR3 Cable Male/Male 1m/3.28ft 28AWG
CAC-2067 The Club 3D DisplayPort™ 1.4 HBR3 cable enables the connection of your DisplayPort™ supported (Gaming) PC or Laptop to an (Ultra) High Resolution Monitor or other DisplayPort™ supported device.
DisplayPort™ 1.4 adds support for Display Stream Compression 1.2 (DSC), Forward Error Correction, and extends the maximum number of inline audio channels to 32.
It features locking DisplayPort™ connectors providing a secure, dependable connection. Simply press the built-in one-touch latch button to unlock the connector. The soft UltraFlex jacket protects the cable from bends and deformation damage.
The Cable is 28AWG and fully Bi-Directional.
Product Name: DisplayPort™ 1.4 HBR3 Cable 8K60Hz Male / Male 1m/3.28ft |
Product Series: Cables |
Item Code: CAC-2067 |
EAN Code: 8719214470814 |
UPC Code: 841615101009 |
Features |
• Fully DisplayPort™ Version 1.4 Compliant, HBR3, 32.4Gbps |
• Downwards compatible to older DisplayPort standards |
• Support resolutions up to 8K @ 60Hz and 4K @ 144Hz |
• Without DSC1.2 max resolution supported up to: - 5K @ 60Hz |
• Certified by VESA |
Operating System Support: |
All |
Connector 1: |
DisplayPort™ Male |
Connector 2: |
DisplayPort™ Male |
• Packaging size: 21.5 X 15 x 1.8 cm/ 8.46 x 5.9 x 0.71" |
• Plastic Bag Weight: 6 gr. |
• Cable Weight: 76 gr. |
• Cable height: 12 mm. |
• Cable width: 19 mm. |
• Cable Size: 1 meter/3.28 feet |
DisplayPort™ 1.4 HBR3 Cable 8K60Hz Male / Male 1M/3.28Ft |
- SPECIFICATION_SHEET_CAC_2067_EN.pdf
- SPECIFICATION_SHEET_CAC_2067_DE.pdf
- SPECIFICATION_SHEET_CAC_2067_ES.pdf
