CAC-1060 - The Club 3D DisplayPort™ 1.4 HBR3 8K cable enables the connection of your DisplayPort™ supported (Gaming) PC or Laptop to an (Ultra) High Resolution
Monitor or other DisplayPort™ supported device. DisplayPort™ 1.4 adds support for Display Stream Compression 1.2 (DSC), Forward Error Correction, and extends the maximum number of inline audio channels to 32.
It features locking DisplayPort™ connectors providing a secure, dependable connection. Simply press the built-in one-touch latch button to unlock the connector. The soft UltraFlex jacket protects the cable from bends and deformation damage.
Product Name: |
DisplayPort™ 1.4 HBR3 8K Cable Male/Male 3M / 9.84ft. |
Product Series: Cables |
Itemcode: CAC-1060 |
EAN code: 8719214471095 |
UPC code: 841615101283 |
• Fully DisplayPort™ 1.4 Compliant, HBR3, 32.4Gbps, 28AWG |
• Downwards compatible to older DisplayPort standards |
• Support resolutions up to 8K @ 60Hz and 4K @ 144Hz |
• Without DSC1.2 max resolution supported up to: - 5K @ 60Hz |
• Vesa Certified |
OS Support: All |
• DisplayPort™ 1.4 Male |
• Box size: 210 x 210 x 50 mm. |
• Box Weight: 64 gr. |
• Product Weight: 219 gr. |
• Weight Product with retail box: 283 gr. |
• Product height: 12mm. |
• Product width: 19 mm. |
• Product Length: 3meter/ 9.84feet |
• Made in China |
Club 3D DisplayPort™ 1.4 HBR3 8K Cable |
