USB3.2 Gen1 Type-C Universal Triple 4K Charging Dock
The CSV-1562 is an USB3.2 Gen1 Type-C Universal Triple 4K Charging Docking Station. The Universal Charging Dock is designed to cater for your most versatile connectivity demands. The USB 3.2 Gen1 interface supports up to 5 Gbps bandwidth, which enables you to enjoy super speed data transmission between your favorite USB peripherals and allows for up to 2x external 4K60Hz displays and 1x 4K30Hz simultaneously(needs DP™ Alt mode support from the source) in addition it offers a wired network connection, up to 1Gbps, as well as audio and micropone output. By adopting PowerDelivery(PD) charging technology, the upstream charging function through USB3.2 Gen1 Type-C interface, you can charge a connected cell phone / tablet / laptop. Furthermore, the added Kensington Lock option allows you to secure your dock as well. All it needs is a free USB 3.2 Gen 1 port on your Laptop or Ultrabook to connect to the Universal Triple 4K Charging Docking Station via a single USB Type-C cable.
Give your Ultrabook more displays Ultrabooks and notebooks are increasingly becoming more powerful and smaller in the physical form factor. With a single USB3.2 Gen 1 port available you can now drive a HDMI™ and/or Displayport™ screen simultaneously. All it needs is a free USB3.2 Gen 1 port on your Telephone, Laptop or Ultrabook to connect to the Universal Triple 4K Charging Docking Station via a single USB cable. The Docking station will provide you with unparalleled connection options for up to three 4K displays. Whether it is thru two times the DisplayPort™ connection or thru 3 times the HDMI™ ports. The setup is easy and simple to do, provided your system supports this function.
Product Name: | |
USB3.2 Gen1 Type-C Universal Triple 4K Charging Dock | |
Product Series: Docking Station | |
Product Code: CSV-1562 | |
EAN code: 8719214471293 | |
UPC code: 841615101481 | |
Features: | |
• Enabling Triple 4K(2x 4K60Hz +1x 4K30Hz) display extension at a time | |
• Upstream port | |
- USB3.2 Gen1 Type-C port x1 | |
• Downstream port | |
- USB3.2 Gen1 Type-A ports (5V/0.9A) x4 | |
- USB3.2 Gen1 Type-A port (Fast Charging) x1 | |
• Support audio 2.1 channel | |
• Support Gigabit Ethernet | |
• Support Displayport™ (4096 x [email protected]) | |
• Support 5K (connect to 2 DP displays simultaneously) | |
• Support HDMI™ ([email protected]) | |
• Support PD Charging (for NB) | |
- 20/15/12/9/[email protected], up to 60W | |
• Kensington Lock | |
• Power On/Off Button on the front | |
OS Support: | |
• Windows®10, Mac OS® | |
In the box: | |
• CSV-1562 Docking Station | |
• External Power Supply 100-240VAC, 135W, PowerCord (specify plug when ordering) | |
• USB-C cable with USB-C to USB-A adapter M/M 1 m/3.28" | |
• Quick Installation Guide | |
Available Interfaces | |
Input: | |
• USB3.2 Gen 1 Type-C Female | |
Output: | |
• 3x HDMI™ Female | |
• 2x DisplayPort™ Female | |
• 5x USB3.2 Gen 1 Type-A Female | |
• 1x USB3.2 Gen 1 Type-C Female For PD charging only | |
• Gigabit Ethernet RJ45 Jack | |
• Headphone and Mic Jacks | |
Other info: | |
• Box size: 29.8 x 9.2 x 15 cm/11.73 x 3.62 x 5.91" | |
• Device size: 25 x 8.3 x 3.4 cm/ 9.84 x 3.27 x 1.34" | |
• Box Weight: 282 gr/9.95 oz | |
• Device Weight: 399 gr/14 oz | |
• USB-C Weight: 55 gr/1.94 oz | |
• Power Adapter Weight: 670 gr/23.63 oz | |
• Total Weight: 1406 gr/49.6 oz | |
• Meets ROHS, FCC, and CE EMI requirements | |
Note: - Please update your TV Firmware to the version which supports these resolutions/refresh rates ! - Please update your Graphic drivers on your PC and make sure that DSC1.2 is supported on your devices to support the these resolutions/refresh rates! | |
POSSIBLE RESOLUTIONS
DOCKING STATION
- CSV-1562_SPECIFICATION-SHEET_EN.pdf
- CSV-1562_SPECIFICATION-SHEET_DE.pdf
- CSV-1562_SPECIFICATION-SHEET_ES.pdf
- CSV-1562-Quick-Instal 2022.pdf
- CSV-1562_Resolution_Test_EN.pdf
