DisplayPort 1.4 HBR3 Extension Cable 8K60Hz M/F 2m/6.56ft
CAC-1022 - The Club 3D DisplayPort™ 1.4 HBR3 Male/Female, 2m/6.56ft. Cable enables the extension of your connection to your DisplayPort™ supported (Gaming) PC or Laptop to an (Ultra) High Resolution Monitor or other DisplayPort™ supported device. DisplayPort™ 1.4 adds support for Display Stream Compression 1.2 (DSC), Forward Error Correction, and extends the maximum number of inline audio channels to 32.
It features locking DisplayPort™ connectors providing a secure, dependable connection. Simply press the built-in one-touch latch button to unlock the connector.
The soft UltraFlex jacket protects the cable from bends and deformation damage. The Cable is 28AWG and fully Bi-Directional.
Product Name: DisplayPort™ 1.4 HBR3 8K60Hz Extension Cable Male/Female 2m/ 6.56 ft 28AWG |
Product Series: Cable |
Itemcode: CAC-1022 |
EAN code: 8719214471316 |
UPC code: 841615101504 |
• Fully DisplayPort™ Version 1.4 Compliant, HBR3, 32.4Gbps |
• Downwards compatible to older DisplayPort standards |
• Support resolutions up to 8K @ 60Hz and 4K @ 144Hz |
• The Cable is 28AWG and fully Bi-Directional |
All |
• Club 3D DisplayPort™ 1.4 HBR3 8K60Hz Extension Cable Male/Female 2m/ 6.56 ft 28AWG. |
• DisplayPort™ 1.4 Female |
• DisplayPort™ 1.4 male |
• Boxsize: 14.5 X 14.5 x 4.5 cm |
• Cable: 200 x 2 x 1 cm |
• Cable Weight: 134 gr. |
• ESD bag: 5 gr. |
• Retail box including cable and ESD, 188 gr. |
• Made in China |
- SPECIFICATION SHEET_CAC-1022_EN.pdf
- SPECIFICATION SHEET_CAC-1022_DE.pdf
- CLUB3D_PROMO-CAC-1022-EN.pdf
- CLUB3D_PROMO-CAC-1022-DE.pdf
