Multi Stream Transport (MST) Hub DisplayPort 1.4 Triple Monitor
CSV-7300 - The Club 3D Multi Stream Transport (MST) Hub DisplayPort™ 1.4 Triple Monitor is an integrated solution that allows you to enjoy displaying content onto three different monitors/displays simultaneously under MST mode.
The three screens can accommodate displaying different contents in parallel or by simply extending the existing screen, giving a panoramic view of the content which maximizes the user’s visual experience. With its multi-display capabilities, this hub can serve as a convenient and hassle-free portable, alternative solution to the conventional docking station. It’s the perfect solution for host devices which feature DP1.2 /1.4 graphic cards that support all DP Alt mode video signal output, for gaming and commercial applications. Supports G-Sync, FreeSync.
Product Name: Multi Stream Transport(MST) Hub DisplayPort™ 1.4 Triple Monitor |
Product Series: Video Splitters |
Item code: CSV-7300 |
EAN code: 8719214471415 |
UPC code: 841615101597 |
• Compliant with DisplayPort™1.4 specification |
• Compliant with HDCP 2.2 specification |
• Supports Triple Monitor 4K60Hz with DSC 1.2 |
• Supports dual [email protected] bpp without compression |
• DSC 1.2 transport and up to 4-slice decompression |
• Supports G-Sync, FreeSync and VRR |
• High Dynamic Range (HDR) video |
• SST or up to 3 stream MST |
Microsoft Windows® 10 |
• CSV-7300, 3 port DisplayPort™ 1.4 MST Hub |
• 1x USB Type A cable for powering the Hub 1 m / 3.28 ft |
• Quick Install Guide |
Available Interfaces: |
• 1x DisplayPort™ Male for connecting to Host |
• 3x DisplayPort™ Female for connecting to monitors |
• 1x DC Power jack(5V / 2.4A) We recommend an external power source which can provide 5V @ 2.4A (12W). |
• Box size: 14.5 x 14.5 x 4.5 cm |
• Box size: 5.7 x 5.7 x 1.77 inch |
• Device size: 7.9 x 7.9 x 1.7 cm |
• Device size: 3.11 x 3.11 x 0.67 inch |
• Cable to Host : 13 cm / 5.12 inch |
• Device Weight: 68gr / 2.4oz |
• USB Type A power cable length: 100 cm/ 39.37 inch |
• USB Type A power cable weight: 24gr / .85oz |
• LDPE Bag Weight: 5gr/ .17oz |
• Box Weight: 24gr / .85oz |
• Total Weight: 121gr / 4.27oz |
- SPECIFICATION SHEET_CSV-7300_EN.pdf
- SPECIFICATION SHEET_CSV-7300_DE.pdf
- SPECIFICATION SHEET_CSV-7300_ES.pdf
