The Club 3D CSV-1542 is a USB Gen2 Type C to 2x USB Gen2 Type A + 2x USB Gen2 Type C Data Hub.
The bus-powered compact and comprehensive super fast data hub allows you virtually to connect all data transfer peripherals, including phones/tablets.
The hub is compatible with both new Gen2 USB peripherals as well as downwards compatible to legacy USB devices, max data tranfer rate up to 10Gbps(1280MB/s).
Extended connection for existing devices, such as a hard drive, SSD, USB flash,mouse, keyboard and/or printer.
The Hub also supports downstream charging, limited to the capabilities of the source.
USB 3.1 Type-C to Type-A Cable 10Gbps PD 60W M/M 1m/3.28ft
USB 3.2 Gen1 Type C to Gigabit Ethernet Active Adapter
USB 3.1 Type C to USB 3.0 Type A Adapter
Product Name: USB Gen2 Type C to 2x USB A + 2x USB C Data Hub
Product Series: Adapter
Product Code: CSV-1542
EAN code: 8719214471644
UPC code: 841615101832
• 2 USB Gen2 Type A output ports
• 2 USB Gen2 Type C output ports
• USB 3.1 port and the max transfer speed up to 10Gbps(1280MB/s)
• USB 3.0 at speed up to max 5Gbps(640MB/s)
• USB 2.0 at speed up to max 480Mbps(60MB/s)
Applications:
• Extending of both USB A and USB C ports x2
• Connecting SSD drives, Hard Disks and/or USB Flash drives
• Connecting Keyboard / mouse to Phones/Tablets
In the box: CSV-1542 Data Hub
• 1x USB Type C(Male)
• 2x USB Type C (Female)
• 2x USB Type A (Female)
• Box size: 24 x 6 x 3.5cm / 9.45 x 2.36 x 1.38 inch
• Device size: 8 x 4 x 1.3 cm / 3.15 x 1.58 x 1.24 inch
• Input Cable length approx.: 12 cm / 4.73 inch
• Connector dimensions:
- USB Type C Male 2.9 x 1.2 x 0.7 cm / 1.15 x 0.5 x 0.28 inch
• Device Weight: 45 gr / 1.59 oz
• Box Weight: 28 gr / 0.99 oz
• LDPE Bag Weight: 5gr / 0.18 oz
• Total Weight: 78 gr / 2.76 oz
In case you need assistance to choose the correct cable, please visit our website www.club-3d.com or feel free to mail us at [email protected]
and it will be our pleasure to assist you.
