HDMI AOC Cable 4K120Hz M/M 20m/65.6 ft
The Club 3D CAC-1379 HDMI™ Active Optical Cable, allows you to connect your favourite Display over a distance of 20 m / 65.62 ft. Nowadays we have many devices that we want to connect to our TV or projector which makes this product a great solution because it creates flexibility for the placing of such devices.
This Ultra High Speed HDMI™ 4K120Hz UHD Cable is fully compliant to HDMI™ 2.1 standard to ensure smooth transfer of your Video and Audio signals over the full length of this Extension Cable.
HDMI [email protected] UHD Splitter 4 Ports
High Speed HDMI™ Extension Cable 4K60Hz M/F 5m/16.4ft 26 AWG
HDMI™ AOC Cable 4K120Hz M/M 20m/65.6 ft
Product Series: Cable
Product Code: CAC-1379
EAN code: 8719214471620
UPC code: 841615101818
• Fully Compliant to Ultra High Speed HDMI™ 2.1 specification
• Professional quality cable
• Supports (U)HD resolutions up to 4K120Hz (with DSC 1.2) or 8K60Hz
• Supports Static- and Dynamic HDR Metadata
• All
• HDMI™ AOC Cable 4K120Hz M/M 20m/65.6 ft
• HDMI™ Type A Male (labeled Source)
• HDMI™ Type A Male (labeled Display)
• Boxsize: 23 x 23 x 5 cm / 9 x 9 x 1.97"
• Connector Dimensions:
- HDMI™ Male: 6.7 x 2 x 0.9 cm / 2.64 x 0.79 x 0.36"
• Cable Length: 20m/65.6ft.80ft
• Box Weight: 110 gr / 3.88 oz
• ProductWeight: 552 gr/19.47 oz
• Total Weight: 662 gr/23.35 oz
In order to achieve these resolutions / refresh rates, Please update your:
- TV Firmware to the version which supports these resolutions/refresh rates!
- Graphic drivers on your PC and make sure that DSC1.2 is supported on your devices to support these resolutions/refresh rates!
In case you need assistance to choose the correct cable, please visit our website www.club-3d.com or feel free to mail us at [email protected] and it will be our pleasure to assist you.
