HDMI AOC Cable  4K120Hz  8K60Hz  Unidirectional  M/M 10m/32.8 ft
The Club 3D CAC-1376 HDMI™ Active Optical Cable, allows you to connect your favourite Display over a distance of 10m / 32.80ft.
HDMI™ Increased Bandwidth to 48Gbps.
The increase in maximum bandwidth compared to previous versions is achieved by increasing both the bitrate of the data channels (from 6Gbps to 12Gbps) and the number of channels (from 3 to 4). This allows support for resolutions up to supports 4K at 120Hz or 8K60Hz!
New feature included in the Specification is Display Stream Compression
(DSC) 1.2 , this is used for video formats higher than 8K with 4:2:0.
HDMI™ also supports Static- and Dynamic HDR metadata.
DisplayPort 1.4 to HDMI 4K120Hz HDR Active Adapter M/F
HDMI AOC Cable 4K120Hz 8K60Hz M/M 20m/65.6 ft
HDMI™ AOC Cable 4K120Hz 8K60Hz Unidirectional M/M 10m/32.8 ft
Product Series: Cable
Product Code: CAC-1376
EAN code: 8719214471729
UPC code: 841615101955
• Fully Compliant to Ultra High Speed HDMI™ specification
• Professional quality cable
• This cable is Uni - Directional because its an Active Cable.
• Supports (U)HD resolutions up to 4K @ 120Hz or 8K60Hz (with DSC 1.2)
• Supports Static- and Dynamic HDR Metadata
In order to achieve these resolutions / refresh rates, Please update your:
- TV Firmware to the version which supports these resolutions/refresh rates!
- Graphic drivers on your PC and make sure that DSC1.2 is supported on your devices to support these resolutions/refresh rates!
• HDMI™ AOC Cable 4K120Hz 8K60Hz Unidirectional M/M 10m / 32.80 ft
• 1x HDMI™ Male (labeled Source)
• 1x HDMI™ Male (labeled Display)
• Box size: 17.5x17.5x4.5cm / 6.89 x 6.89 x 1.77 inch
• Cable Length: 10 m / 32.8 ft
• Connector Dimensions: HDMI™ Male: 6.7 x 2 x 0.9 cm / 2.64 x 0.79 x 0.36 inch
• Cable Weight: 302 gr / 10.65 oz
• Box Weight: 63 gr / 2.22 oz
• Total Weight: 365 gr / 12.875 oz
