Ultra High Speed HDMI 4K120Hz, 8K60Hz Cable 48Gbps M/M 4 m/13.12ft 26AWG
The Club 3D CAC-1374 Ultra High Speed HDMI™2.1 Cable is built to handle the highest quality video- and audio- signals.
The increase in maximum bandwidth compared to previous versions is achieved by increasing both the bitrate of the data channels (from 6Gbps to 12Gbps) and the number of channels (from 3 to 4). This allows support for resolutions up to supports 4K at 120Hz! New feature included in this Specification is Display Stream Compression (DSC) 1.2 , this is used for video formats higher than 8K with 4:2:0.
- HDMI™2.1 also supports Static- and Dynamic HDR metadata.
All HDMI™2.1 features are fully supported by this Club3D CAC-1374 Cable. It is the ideal solution for the ultimate future proof HDMI™2.1 experience.
Ultra High Speed HDMI 4K120Hz, 8K60Hz  Cable 48Gbps M/M  3 m/ 9.84ft
Ultra High Speed HDMI™ Certified AOC Cable 4K120Hz/8K60Hz Unidirectional  M/M 10m/32.80ft
Ultra High Speed HDMI™ 4K120Hz, 8K60Hz Cable
Product Series: Cable
Product Code: CAC-1374
EAN code: 8719214471873
UPC code: 841615102082
• Fully Compliant to the Ultra High Speed HDMI™2.1 specification
• Professional quality cable
• Low EMI emission
• Gold plated connectors for maximum conductivity and 26 AWG
• Enhanced gaming and media features
• Color space BT.2020 with 10bits,12bits,16bits
• Supports (U)HD resolutions up to 4K120Hz (with DSC 1.2) or 8K60Hz
• Supports Static- and Dynamic- HDR Metadata
• All
• 1x Ultra High Speed HDMI™ 4K120Hz, 8K60Hz
• HDMI™ Male
• HDMI™ Male
• Box size: 17.5 x 17.5 x 6cm / 6.89 x 6.89 x 2.36"
• Cable length approx.: 4 m/13.12ft
• Connector dimensions: 5 x 2 x 1 cm / 1.97 x 0.79 x 0.39"
• Cable Weight: 322gr / 11.35 oz
• Box Weight: 70gr / 2.47 oz
• LDPE Bag Weight: 8 gr / 0.28 oz
• Total Weight: 400gr / 14.11 oz
Note:
