USB Gen1 Type-C 8-in-1 MST Dual 4K60Hz Display Travel Dock
The Club 3D CSV-1597 USB Gen1 Type-C 8-in-1 MST Dual 4k60Hz Display Travel Dock with HDMI™8K30Hz(HDR), DisplayPort™ 8K30Hz, 2x USB Gen1 Type-A, BC1.2, RJ45, SD/Micro SD card slots and USB Gen1 Type-C PD3.0 Female port, provides a very advanced, efficient solution to extend a single USB Gen1 Type-C port to be multiple ports. It integrates video, data and power ports that allows to connect 2 displays simultaneously for enjoying videos on a larger screen, connect multiple USB Gen1 devices for data transmission up to 5Gbps, connect a Gigabit Ethernet source for getting your PC connected to super high speed network, or connect to headset to enjoy fantastic music. It also provides PD3.0 charging for support up to max. 100W PD charging. This is for operating this device and charge the host simultaneously. It can work on all DP™1.4 Alt mode supported USB Gen1 Type-C hosts.
Ultra High Speed HDMI 4K120Hz, 8K60Hz  Cable 48Gbps M/M  3 m/ 9.84ft
USB Gen1 Type-C 6-in-1 Hub with HDMI 8K30Hz-4K120Hz, 2xUSB Type-A, RJ45 and 2xUSB Type-C, Data and PD charging 100 watt
USB Gen 1 Type-C 8-in-1 MST Dual 4K60Hz Display Travel Dock
Product Series: Docking
Product Code: CSV-1597
EAN code: 8719214472368
UPC code: 841615102716
• Support DP™1.4 Alt mode max. 8K@30Hz(with DSC1.2)
• Support HDMI™ max. 8K@30Hz(with DSC1.2)
• Support Dual display HDMI™+ DP™ max.4K60Hz (MST with DSC1.2)
• Max 5Gbps data transmission per USB Gen 1 Type-A port
•Support max 7.5W(5V/1.5A) downstream charging, 2  USB Gen1 Type-A share max 2.5A(12.5Watt) output
• Support Gigabit Ethernet 10M/100M/1000M
• Support SD3.0 UHS-I up to 832Mbps/104MB/s data rate, allow 2 card slots to work simultaneously
• Support PD3.0 with max. 100W PD charging
NOTE: Please make sure your host supports DP™1.4 Alt mode.
• 1x USB Gen 1Type-C Male(Connect to host)
Note: To get max. bandwidth, the host should support DP™1.4 Alt mode
Output(s):
• 1x HDMI™
 Support max. 8K30Hz
• 1x DisplayPort™
 Support max. 8K30Hz
 - Support Dual display HDMI™+ DP™ max.4K60Hz (MST with DSC1.2)
Note: The max. resolution of the display determined by the computer and the monitor
• 2x USB Gen 1 Type-A
 Max. 5Gbps data transmission per port
 Support max. 7.5W(5V/1.5A) downstream charging.
 2 USB Gen1 Type-A ports share max 2.5A(12.5Watt) output
 Support short-circuit, over-current, over-voltage protection
• 1x RJ45
 Support Gigabit Ethernet,10M/100M/1000M
• 2x SD/Micro SD 3.0
 Support UHS-I up to 832Mbps/104MB/s data rate
 Allow 2 card slots to work simultaneously
• 1x USB Gen 1 Type-C Female (for PD Charging)
 Support max. 100W PD charging
 Support PD3.0 Fast Role Swap, the connected device will not get disconnected while plugging in and out the PD
• Microsoft® and Apple®
• 1x USB Gen 1 Type-C 8-in-1 MST Dual 4K60Hz Display Travel Dock
• USB Gen 1 Type-C Male
(Connect to host)
• 1x HDMI™ Female
• 1x DisplayPort™ Female
• 2x USB Gen 1 Type-A Female
• 1x RJ45
• 1x SD / 1x Micro SD 3.0
• Box size: 25 x 8 x 3.5cm / 9.84 x 3.15 x 1.38"
• Cable length: 18 cm / 7.09"
• Total length: ± 31.6 cm / 12.44"
• Hub dimensions: 13 x 4.5 x 1.4 cm / 5.12 x 1.77 x 0.55"
• Connector dimensions: 3.4 x 1.2 x x 0.65 cm / 0.86 x 0.47 x 0.26"
• Product Weight: 82 gr / 4.13 oz
• Box Weight: 54 gr / 1.9 oz
• Total Weight: 136 gr / 4.79 oz
Note:
