DisplayPort 1.4 to HDMI 4K120Hz or 8K60Hz HDR10 Cable M/M 3m/9.84ft
The Club 3D CAC-1087 is the perfect solution to connect to any HDMI™ 4K120Hz or 8K60Hz ready displays*. If you have a DisplayPort™ 1.4 ready PC or any other device that lacks the new HDMI™ 4K120Hz or 8K60Hz specification, the Club3D CAC-1087 will be the simple way to upgrade your device and connect to your new TV*.
With its DP1.4 DSC video compression technology, this adapter is able to convert DP1.4 video signals to HDMI™, supporting video display resolutions up to 8K (7680x4320/60HZ or 3840x2160/120Hz) and creating life like colors and movements with HDR10 giving users the ultimate visual experience. The Adapter is powered thru the DP™ port.
Product Name: |
DisplayPort™ 1.4 to HDMI™ 4K120Hz or 8K60Hz HDR10 Cable M/M 3m/9.84ft |
Product Series: Cable |
Product Code: CAC-1087 |
EAN code: 8719214472436 |
UPC code: 841615102709 |
• Compliant with VESA DisplayPort™ v1.4 Specification |
• Compliant with HDMI™ 2.1 Specification |
• Support both HDCP 1.4 and HDCP 2.2 |
• Support DSC v1.2a and backward compatible with the former version |
• Support Max. resolution/refresh rates up to 4K120Hz or 8K60Hz |
• Support Dynamic HDR10 |
Applications: |
• For the host device like laptop, desktop, video converter adaptor, docking station, projector, gaming and display system like TV*, digital signage, VR/AR system. |
• Perfect for Host Devices which are featured with the DP1.4 graphic card that supports DP video signal output for gaming, commercial applications**. |
Supported resolutions: |
• Support Max. resolution/timing up to 4K120Hz or 8K60Hz |
This adapter will function with lower specifications GPU’s, be aware performance will be reduced due to the specifications of that GPU !! |
• Microsoft, Mac OS |
• CAC-1087 DisplayPort™ 1.4 to HDMI™ 4K120Hz or 8K60Hz HDR10 Cable M/M 3m/9.84ft |
Available Interfaces |
• 1x DP1.4 (Male) |
• 1x HDMI™ (Female) |
• Box size: 21 x 21 x 3.5 cm / 8.27 x 8.27 x 1.38" |
• Cable Length : 3m / 9.84ft |
• Connector dimensions: |
- DisplayPort™ Male 4.5 x 2 x 1.5 cm / 1.78 x 0.79 x 0.6 " |
- HDMI™ Male 6.3 x 2 x 1.1 cm / 2.48 x 0.79 x 0.43" |
• Cable Weight: 139 gr / 4.9 oz |
• Box Weight: 70 gr / 2.47 oz |
• Bio Degradable Bag Weight: 5gr / 0.18 oz |
• Total Weight: 214 gr / 7.55 oz |
Note: - Please update your TV Firmware to the version which supports these resolutions/refresh rates ! - Please update your Graphic drivers on your PC and make sure that DSC1.2 is supported on your devices to support the these resolutions/refresh rates! |
- CAC-1087_SPECIFICATION-SHEET_EN.pdf
- CAC-1087_SPECIFICATION-SHEET_DE.pdf
- CAC-1087_SPECIFICATION-SHEET_ES.pdf
