Ultra High Speed HDMI Extension Cable 4K120Hz  8K60Hz  48Gbps M/F 1 m / 3.28 ft 30AWG
The Club 3D CAC-1322 Ultra High Speed HDMI™2.1 Extension Cable is built to handle the highest quality video- and audio- signals. HDMI™2.1 Increased Bandwidth to 48Gbps.The increase in maximum bandwidth compared to previous versions is achieved by increasing both the bitrate of the data channels (from 6Gbps to 12Gbps) and the number of channels (from 3 to 4). This allows support for resolutions up to supports 4K120Hz or 8K60Hz! New feature included in this Specification is Display Stream Compression (DSC) 1.2, this is used for video formats higher than 8K with 4:2:0.
• Variable Refresh Rate (VRR) reduces or eliminates lag, stutter and frame tearing for more fluid motion in games
• Quick Media Switching (QMS) for movies and video eliminates the delay that can result in blank screens before content is displayed
• Quick Frame Transport (QFT) reduces latency.
• HDMI™2.1 also supports Static- and Dynamic HDR metadata.
All HDMI™2.1 features are fully supported by this Club 3D CAC-1322 Cable. It is the ideal solution for the ultimate future proof HDMI™2.1 experience.
Ultra High Speed HDMI 4K120Hz, 8K60Hz  Certified Cable 48Gbps M/M  1 m/3.28 ft
Ultra High Speed HDMI 4K120Hz, 8K60Hz  Cable 48Gbps M/M  3 m/ 9.84ft
Ultra High Speed HDMI 4K120Hz, 8K60Hz Cable 48Gbps M/M 4 m/13.12ft 26AWG
Ultra High Speed HDMI™ Extension Cable 4K120Hz 8K60Hz 48Gbps M/F 1 m / 3.28 ft 30AWG
Product Series: Cable
Product Code: CAC-1322
EAN code: 8719214472665
UPC code: 841615102907
• Fully Compliant to the Ultra High Speed HDMI™2.1 specification
• Professional quality cable
• Low EMI emission
• Gold plated connectors for maximum conductivity and 30AWG
• Enhanced gaming and media features
• Color space BT.2020 with 10bits,12bits,16bits
• Supports (U)HD resolutions up to 4K120Hz or 8K60Hz(with DSC 1.2)
• Supports Static- and Dynamic- HDR Metadata
• All
• 1x Ultra High Speed HDMI™ Extension Cable 4K120Hz 8K60Hz 48Gbps M/F 1 m / 3.28 ft 30AWG
• HDMI™ Male
• HDMI™ Female
• Box size: 17.5 x 17.5 x 4.5 cm / 6.89 x 6.89 x 1.77"
• Cable length approx.: 1 m / 3.28 ft
• Connector dimensions: 5 x 2 x 1 cm / 1.97 x 0.79 x 0.39 inch
• Cable Weight: 103 gr / 3.63 oz
• Box Weight: 63 gr / 2.22 oz
• LDPE Bag Weight: 9 gr / 0.32 oz
• Total Weight: 175 gr / 6.17 oz
Note:
