DisplayPort 2.1 Bi-Directional VESA DP80 Certified Cable 4K240Hz, 8K60Hz or 10K60Hz M/M 1.2m/3.94ft
The Club 3D CAC-1091 DisplayPort™ 2.1 Cable enables the connection of your DisplayPort™ supported (Gaming) PC or Laptop to an (Ultra) High Resolution Monitor or other DisplayPort™ supported device. DisplayPort™ 2.1 UHBR10/13.5/20 up till 80 Gbps, also has support for Display Stream Compression 1.2 (DSC), Forward Error Correction, and extends the maximum number of inline audio channels to 32. Thanks to improvements in both the DisplayPort™ connector and cable design, the new VESA certified DP80 UHBR cables enable consumers to get the highest performance possible from their VESA certified devices. These new cables are backed by VESA’s UHBR Certification Program, which provides added assurance that if your cable has the DP40 or DP80 logo from VESA, it will meet the specs for the highest data rates supported by current and future products certified by VESA. Simply press the built-in one-touch latch button to unlock the connector. The soft UltraFlex jacket protects the cable from bends and deformation damage.
Product Name: DisplayPort™ 2.1 Bi-Directional VESA DP80 Certified Cable 4K240Hz, 8K60Hz or 10K60Hz M/M 1.2m/3.94ft |
Product Series: Cable |
Product Code: CAC-1091 |
EAN code: 8719214472696 |
UPC code: 841615102938 |
• Fully DisplayPort™ Version 2.1 Compliant, UHBR10/13.5/20 up till 80 Gbps |
• DP80 Compliant |
• New DP2.1 spec connector |
• Downwards compatible to older Displayport standards |
• Support resolutions up to 4K240Hz, 8K60Hz or 10K60Hz |
• Fully Bidirectional |
• VESA Certified |
• Works with Windows, Apple OS X, Chrome OS |
• 1x CAC-1091 a DisplayPort™ 2.1 Bi-Directional VESA DP80 Certified Cable 4K240Hz, 8K60Hz or 10K60Hz M/M 1.2m/3.94ft |
Available Interfaces |
• DisplayPort 2.1 Male (NEW DP80 connector) |
• Box size: 14.5 x 14.5 x 4.5cm 5.71 x 5.71 x 1.77" |
• Total Cable length approx.: 1.2m / 3.94ft |
• DisplayPort™ Male Connector dimensions: 3.62 x 1.2 x 0.63 cm / 1.43 x 0.47 x 0.25" |
• Cable Weight: 85 gr / 3 oz |
• Bio Degradable Bag Weight: 5 gr / 0.17 oz |
• Box Weight: 45 gr / 1.59 oz |
• Total Weight: 135 gr / 4.76 oz |
- CAC-1091_SPECIFICATION-SHEET_EN.pdf
- CAC-1091_SPECIFICATION-SHEET_DE.pdf
- CAC-1091_SPECIFICATION-SHEET_ES.pdf
