Product Name: |
1 to 8 HDMI™ Splitter Full 3D and 4K60Hz(600MHz) |
Product Code: CSV-1383 |
EAN code: 8719214472771 |
UPC code: 841615103034 |
• Easy to Use: Install in seconds, no need for settings |
• One HDMI™ Input, eight HDMI™ outputs |
• Support 12-bit Deep Full HD, Full 3D, HDR and 4K60Hz video |
• Vertical Frequency Range 24-30-50-60Hz |
• Resolution HDTV |
Interlaced (50&60Hz) 480i,576i,1080i |
Progressive (50&60Hz) Max. up to 4K@60Hz |
• Support compressed audio |
• Support HDCP 2.2 |
• Power Protection: the power will get disconnected automatically once the voltage of the connected power adapter is above 5.5V (Note: the power protection circuit will be damaged if the voltage if above 30V, so avoid connecting power adapter with voltage above 30V) |
• OS Support: Windows10/11 |
• Warning Safe Usage – Product Only to be used at altitude 2000 meters/6562 feet and below |
• Windows10/11 |
• Club 3D CSV-1383 1 to 8 HDMI™ Splitter |
• Power Supply 100-240VAC/ 5V3A DC(Please Specify Plug type when ordering) |
• QR Code for downloading the Quick Install Guide (QIG) |
Available Interfaces |
• 1x HDMI™ Female |
• 8x HDMI™ Female |
• Box size: 35 x 13 x 5.5 cm / 13.78 x 5.12 x 2.17" |
• Switch size: 25.8 x 11.35 x 3.5 cm / 10.16 x 4.47 x 1.38" |
• Box Weight: |
• ProductWeight: 770 gr / 27.16 oz |
• Power Supply Weight: 127 gr / 4.48 oz (Depending on PowerPlug) |
• Total Weight: (Depending on PowerPlug) |
Note: |
