Thunderbolt™ 5  Certified 8K240Hz Data 80/120 Gbps EPR 240 Watt Cable M/M  1m / 3.28ft
• HIGH PERFORMANCE: 1m / 3.28ft Thunderbolt™ 5 cable supports 80 Gbps, 8K video, and 240W  EPR power; USB Type-C® to Type-C® connectors offer universal compatibility with Thunderbolt™ 3 & 4, USB80Gbps, and other USB Type-C® devices
• THUNDERBOLT CERTIFIED: Intel Thunderbolt™ certified for guaranteed compatibility with Thunderbolt™ hosts and devices; DisplayPort™ 2.1 with DSC supports up to 4K540Hz or dual 8K240Hz; Compliant with PCI Express 64 Gbps for external PCIe devices
• QUALITY CONSTRUCTION:  Nickel-plated connectors with PVC strain reliefs for durability; Twisted Pair wire with braided alloy shield for enhanced EMI protection; Durable TPE outer jacket is environmentally friendly, non-toxic, halogen-free, and RoHS compliant
• APPLICATIONS: Versatile connectivity with Thunderbolt™ 5 and USB Type-C® laptops, iPad Pro (5th gen and newer), docking stations, 4K/8K monitors, external PCIe chassis and storage drives; Low-latency performance with Thunderbolt™ 5 networking 64Gbps and audio devices
• SPECS: 1m / 3.28ft; Black; Thunderbolt™ 5 (80/120Gbps); USB 80Gbps and lower versions; DisplayPort™ 2.1 w/ DSC; 8K240Hz or Dual 4K144Hz; PCIe 64Gbps ; 240W PD; Twisted Pair Cable Outer Diam.: 4.8mm / 0.19in
USB 80Gbps Certified 240W 8K240Hz Type-C® 1.2m / 3.94ft Black Cable
Product Name: Thunderbolt™ 5  Certified 8K240Hz Data 80/120 Gbps EPR 240 Watt Cable M/M  1m / 3.28ft
Product Series: Cable
Product Code: CAC-2501
EAN code: 8719214473280
UPC code: 841615103522
Supported resolutions:
• 1x 4K540Hz
• 2x 8K60Hz
• 3x 4K144Hz*
*NOTE:
• Maximum theoretical bandwidth, realized performance dependent on specific HW and SW configuration
• Windows 10 or upwards, macOS 15.0
In the box
• 1x CAC-2501 Thunderbolt™ 5  Certified 8K240Hz Data 80/120 Gbps EPR 240 Watt Cable M/M  1m / 3.28ft
• USB Type-C® Male
• USB Type-C® Male
Box size: 10 x 10 x 3.5cm / 3.94 x 3.94 x 1.38inch
• Cable Length: 1m / 3.28ft
• Connector dimensions:2.27 x 1.24 x 0.65cm / 0.89 x 0.49 x0.26inch
• Cable Weight: 45gr / 1.59 oz
• Box Weight: 22gr / 0.78 oz
• Bio Degradable Bag size: 21 x 13cm / 8.27 x 5.12inch
• Bio Degradable Bag Weight: 2gr./ 0.07oz
• Total Weight: 69gr / 2.43oz
Notes:
- Please update your TV Firmware to the version which supports these resolutions/refresh rates
- Please update your Graphic drivers on your PC and make sure that DSC1.2 is supported on your devices to support the these resolutions/refresh rates
Club 3D uses Bio-Degradable bags according to the EN/DIN 13432
