USB 5Gbps Type-C® to RJ45 Ethernet M/F
• USB 5Gbps Type-C® NETWORK ADAPTER: USB 5Gbps Type-C® to RJ45 Ethernet M/F Converter allows you to add 5GbE network access to a laptop, tablet, or iPhone using an available USB Type-C® port; Doubles network performance on existing Cat5 cables
• BROAD COMPATIBILITY: Auto-installs most operating systems including Windows10 and up, macOS 15.0
• 5Gbps BANDWIDTH: 4-speed auto-negotiation for optimal performance with network devices; Extend system longevity by retrofitting older systems
• APPLICATIONS: Slim form factor adapter for office/hotel desks; Quickly download large files from a network, experience higher quality video conferencing & sync files to the cloud in the background with a faster/more secure connection compared to wireless
• TECH SPECS: USB 5Gbps Type-C®  Adapter; 1x RJ45; 12 cm / 4.72 in attached Cable; 5Gbps Multi-Gigabit; 10/100/1000/2500/5000Mbps; WoL; VLAN; MDIX; Jumbo Frames; USB Pass through; USB Bus Powered
USB 3.2 Gen1 Type C to RJ45 2.5Gbps Adapter
USB 5Gbps Type-A to RJ45 Ethernet M/F
USB 3.2 Gen1 Type-A to RJ45 2.5Gbps Adapter M/F
Product Name: USB 5Gbps Type-C® to RJ45 Ethernet M/F
Product Series: Adapter
Product Code: CAC-2530
EAN code: 8719214473327
UPC code: 841615103577
Supported Bandwidth(s):
• 10M/100M/1G/2.5G/5 Gbps
• Auto MDIX supported
• Support Jumbo Frames
• Support USB pass Through
• Power consumption: 4.75 - 5.25 Volt
• Operating current: <350mA(for all speeds)
• Standby current: <100mA(When Ethernet cable is NOT connected)
• Windows 10 or upwards, macOS 15.0
In the box
• 1X CAC-2530 USB 5Gbps Type-C® to RJ45 Ethernet M/F
Note : Driver Software installation might be required
• USB 5Gbps Type-C® Male
• RJ45 Ethernet Jack Female
• Box size: 10 x 10 3.5 cm / 3.94 x 3.94 x 1.38 in
• Device size: 7.8 x 2.7 x 1.5 cm / 3.07 x 1.06 x 0.6 in
• USB Cable length approx.: 12 cm / 4.72 in
• USB Type-C® Connector dimensions: 2 x 1.5 x 0.7 cm / 0.78 x 0.59 x 0.28 in
• Device Weight: 35 gr / 1.24 oz
• Box Weight: 22gr / 0.78 oz
• Bio Degradable Bag size: 9 x 3 cm / 3.54 x 1.18 in
• Bio Degradable Bag Weight: 3 gr./ 0.1 oz
• Total Weight: 60 gr / 2.12 oz
 Warning Safe Usage - Product Only to be used at altitude 2000 meters/6562 feet and below
Club 3D uses Bio-Degradable bags according to the EN/DIN 13432
Disclaimer: While we endeavour to provide the most accurate, up-to-date information available, the content on this document may be out of date or include omissions, inaccuracies or other errors. Products might obtain a certification during their lifetime. This doesn’t change or alter the product specifications and/or performance in any way. Club 3D will provide the updated information on their website www.club-3d.com at her discretion. Therefore Club 3D does not accept any rights claimed on the content of this document. Please refer to a full overview of our Legacy Terms and Conditions on www.club-3d.com. All other brand names are trademarks or registered trademarks and are the property of their respective owners. All content is subject to change without prior notice.
