Mini DisplayPort™ 1.4 to HDMI™ 8K60Hz M/F Adapter
The Club 3D CAC-1188 is the perfect solution to connect to any HDMI™ 8K60Hz or 4K120Hz ready display. When you have a  PC with a Mini DisplayPort™ 1.4 connection or any other device that lacks the new HDMI™ 8K60Hz or 4K120Hz  specification, the Club3D CAC-1188 will be the simple way to upgrade your device and connect to your new TV. The Adapter is powered thru the Mini DisplayPort™ connection.
• PRODUCT PERFORMANCE: Mini DisplayPort™ 1.4 to HDMI™ adapter supports 8K60Hz (7680x4320 @ 60Hz)or 4K120Hz( 3840x2160@ 120Hz), HDCP 2.2 | 9 cm / 3.55 in attached cable  • HOST COMPATIBILITY: Active Mini DP™ to HDMI™ adapter supports Mini DisplayPort™ 1.4 standard
• INCREASE PRODUCTIVITY: Mini DisplayPort™ 1.4 to HDMI™ display adapter connects an HDMI™ 8K60Hz monitor, TV or projector, or add a second display to your workstation; Compact, small form factor design makes it easy to carry between home office and office
• RELIABLE CONNECTION: MiniDisplayPort™ to HDMI™ video converter is designed with nickel-plated connectors to ensure enhanced signal quality 32 AWG Tested with Club 3D Ultra High Speed Certified HDMI™ cables up to 7.5m / 24.61 ft | Mini DisplayPort™ 1.4 Male to HDMI™ Female
• EASY TO USE: With no software or drivers required, the Mini DisplayPort™ to HDMI™ adapter dongle works with Windows 10 upwards, macOS 15, Compatible with MiniDP™ 1.4 supported devices
Mini DisplayPort 1.4 to HDMI 4K120Hz with DSC1.2 Active Adapter M/F
USB Gen2 Type C to HDMI 4K120Hz HDR10 with DSC 1.2 Active Adapter M/F
Product Name: Mini DisplayPort™ 1.4 to HDMI™ 8K60Hz M/F Adapter
Product Series: Adapter
Product Code: CAC-1188
EAN code: 8719214473341
UPC code: 841615103591
• Compliant with VESA® DisplayPort™ v1.4 Specification
• Compliant with HDMI™ 4K120Hz Specification
• Support HDCP 2.2
• Support Max. resolution/refresh rates up to 8K60Hz or 4k120Hz
• Support Dynamic HDR10
• No External Power needed (Powered thru the Mini-DisplayPort™ connection)
Applications:
• For the host device like laptop, desktop, projector, gaming and display system like TV*, digital signage, VR/AR system.
• Perfect for Host Devices which are featured with the DP1.4™ graphic card that supports DP™ video signal thru a mini-DP™ output for gaming, commercial applications
• Windows 10 or upwards, macOS 15.0
• 1X CAC-1188 Mini DisplayPort™ 1.4 to HDMI™ 8K60Hz M/F Adapter
Available Interfaces:
Input:  Mini DisplayPort™ Male
Output:  HDMI™ Female
Box Size: 6 x 18 x 3.5 cm / 7.16 x 2.36 x 1.38in
Device size: 4.8 x 2.25 x 1.15 cm / 1.92 x 0.88 x 0.45in
Cable length approx.: 9 cm / 3.54in
Mini DisplayPort™ Connector dimensions: 0.92 x 1.1 x 2.35cm / 0.36 x 0.43 x 0.93in
Device Weight: 21gr / 0.74oz
Box Weight: 22 gr. / 0.78 oz
Bio Degradable Bag size: 9 x 24 cm / 3.54 x 9.45in
Bio Degradable Bag Weight: 3 gr./ 0.1 oz
Total Weight: 46gr / 1.62oz
Meets ROHS, FCC, and CE EMI requirements
Notes:
Please update your TV Firmware to the version which supports these resolutions/refresh rates
Please update your Graphic drivers on your PC and make sure that DSC1.2 is supported on your devices to support the these resolutions/refresh rates
Warning Safe Usage
Product Only to be used at altitude 2000 meters/6562 feet and below
Club 3D uses Bio-Degradable bags according to the EN/DIN 13432
While we endeavour to provide the most accurate, up-to-date information available, the content on this document may be out of date or include omissions, inaccuracies or other errors. Products might obtain a certification during their lifetime. This doesn’t change or alter the product specifications and/or performance in any way. Club 3D will provide the updated information on their website www.club-3d.com at her discretion. Therefore Club 3D does not accept any rights claimed on the content of this document. Please refer to a full overview of our Legacy Terms and Conditions on www.club-3d.com. All other brand names are trademarks or registered trademarks and are the property of their respective owners. All content is subject to change without prior notice.
