Mini DisplayPort 1.2 Cable to HDMI UHD 4K60Hz Active Adapter M/M 3m/9.84Ft
CAC-1173 The Club 3D CAC-1173 is an active HDMI™ signal converter. The Mini DisplayPort™ 1.2 to HDMI™ 2.0 Cable Active Adapter is the easiest solution for connecting your Mini DisplayPort™ 1.2 enabled Game PC or Laptop to an HDMI™ 2.0 enabled 4K UHD Television, monitor or Projector. The adapter is fully compliant to HDMI™ 2.0 specification allowing for 6Gbps TMDS throughput per channel. The interface in the adapter has three lanes for HDMI data, clock, HPD signal and power, offering a total TMDS throughput of 18Gbps.
Supports up to 4K UHD Resolution at 60Hz. The Mini DisplayPort™ 1.2 to HDMI 2.0 Cable Active Adapter supports (U)HD resolutions of up to 4K UHD 3840x 2160p @ 60Hz for a clear, sharp picture. The support for 60 frames per second provides exceptionally smooth video or gameplay. Use the adapter to play games, view video or browse the internet from your Mini DisplayPort™ 1.2 enabled device in (Ultra) high-resolution. Supporting up to 8 channels of audio, the adapter provides Ultra High Definition digital audio and video. It is the ideal solution for anyone who wants to enjoy 4K UHD/ 60 game-play but lacks a native HDMI™ 2.0 output in their system configuration.The Club 3D is an active HDMI™ signal converter. The Mini DisplayPort™ 1.2 to HDMI™ 2.0 Cable Active Adapter is the easiest solution for connecting your Mini DisplayPort™ 1.2 enabled Game PC or Laptop to an HDMI™ 2.0 enabled 4K UHD Television, monitor or Projector. The adapter is fully compliant to HDMI™ 2.0 specification allowing for 6Gbps TMDS throughput per channel. The interface in the adapter has three lanes for HDMI data, clock, HPD signal and power, offering a total TMDS throughput of 18Gbps.
Model |
Product Name: Mini DisplayPort™ 1.2 Cable to HDMI™ 2.0 UHD 4K60Hz Active Adapter 3m/9.84feet |
Product Series: Cable |
Item Code: CAC-1173 |
EAN Code: 8719214470579 |
UPC Code: 841615100750 |
Features |
• Compliant to DisplayPort™ Specification 1.2 for 1.62Gbps,2.7Gbps and |
• 5.4Gbps per lane. Effective video bandwidth 17.28Gbps |
• Compliant to HDMI™ Specification 2.0, data rate up to 6Gbps per TMDS channel. Total throughput 18Gbps |
• Supports full link training and no link training |
• Repeater for HDCP 1.3 and HDCP 2.2 |
• Supports UHD resolutions up to 4096 x 2160p @ 60Hz, 8Bit BPC |
• Supports 3D video support up to 1080p @120Hz |
• Supports RGB up to 12 bpc, YCbCr -4:2:2 -4:2:0 up to 12 bpc |
• Supports AMD Eyefinity Feature |
Compatibility |
Supports AMD HD6xxx, Nvidia® Maxwell cards and Intel® Skylake HD 5XX series and newer. Not intended for older architectures (such as Intel Haswell HD 4XXX / NVidia Kepler 5xx series Graphics) |
Connector 1: |
Mini DisplayPort™ 1.2 Male |
Connector 2: |
HDMI™ 2.0 Male |
Operating Systems |
Windows 10/8.1, Apple OS X |
• Boxsize: 175 x 175x 45 mm. |
• Cable Weight: 160 gr. |
• Cable Size: 3meters / 9.84feet |
In the Box |
Club3D Mini DisplayPort™ 1.2 to HDMI™ 2.0 UHD 4K60Hz Active Cable 3m/9.84feet |
