Mini DisplayPort 1.4 HBR3 Cable M/M 2m / 6.56ft 34 AWG
CAC-1164 The Club 3D Mini DisplayPort™ 1.4 HBR3 cable enables the connection of your Mini DisplayPort™ supported (Gaming) PC or Laptop to an (Ultra) High Resolution Monitor or other Mini DisplayPort™ supported device. Mini DisplayPort™ 1.4 adds support for Display Stream Compression 1.2 (DSC), Forward Error Correction, and extends the maximum number of inline audio channels to 32.
Maximum resolution: |
Using DSC with HBR3 transmission rates, DisplayPort 1.4 can support up to; |
- 8K @ 60Hz |
- 4K @ 144 Hz |
Without compression (DSC) DisplayPort 1.4 can support up to: - 5K @ 60Hz |
Connector 1: Mini DisplayPort™ Male |
Connector 2: Mini DisplayPort™ Male |
Model |
Product Name: Mini DisplayPort™ 1.4 HBR3 8K60Hz Cable Male / Male 2 mtr. / 6.56 Ft. |
Product Series: Accessories |
Weight: 91 gr |
Cable length: 2 meters / 6.56 feet |
Item Code: CAC-1164 |
EAN Code: 8719214470647 |
UPC Code: 841615100828 |
Features |
• Fully DisplayPort™ Version 1.4 Compliant, HBR3, 32.4Gbps |
• Downwards compatible to older Displayport standards |
• Support resolutions up to 8K @ 60Hz and 4K @ 144Hz |
Operating System Support |
All |
In the box |
