Mini DisplayPort 1.2 Cable to HDMI UHD 4K60Hz Active Adapter Male/Male 3M / 9.84Ft
The Club 3D CAC-1173 is an active HDMI™ up to UHD 4K60Hz signal converter. The Mini DisplayPort™ 1.2 Cable to HDMI™ Active Adapter is the easiest solution for connecting your Mini DisplayPort™ 1.2 enabled Game PC or Laptop to an HDMI™ enabled 4K UHD Television, monitor or Projector. The adapter is fully compliant to HDMI™ specification allowing for 6Gbps TMDS throughput per channel. The interface in the adapter has three lanes for HDMI data, clock, HPD signal and power, offering a total TMDS throughput of 18Gbps. Supports up to UHD Resolution at 4K60Hz. The Mini DisplayPort™ 1.2 Cable to HDMI Active Adapter supports (U)HD resolutions of up to 4K UHD 3840x 2160p @ 60Hz for a clear, sharp picture. The support for 60 frames per second provides exceptionally smooth video or gameplay. Use the adapter to play games, view video or browse the internet from your Mini Display-Port™ 1.2 enabled device in (Ultra) high- resolution. Supporting up to 8 channels of audio, the adapter provides Ultra High Definition digital audio and video. It is the ideal solution for anyone who wants to enjoy 4K UHD/60 Hz game-play but lacks a native HDMI™ 2.0 output in their system configuration.
Premium High Speed HDMI™ 4K60Hz UHD Cable M/M 1 m / 3.28 ft 30AWG
Mini DisplayPort™ 1.2 Cable to HDMI™ UHD 4K60Hz Active Adapter Male/Male 3M / 9.84Ft
Product Series: Cables
Product Code: CAC-1173
EAN code: 8719214470579
UPC code: 841615100750
• Compliant to DisplayPort™ Specification 1.2 for 1.62Gbps,2.7Gbps and 5.4Gbps per lane. Effective video bandwidth 17.28Gbps
• Supports UHD resolutions up to 3840 x 2160p @ 60Hz and 1080p 3D
• Repeater for HDCP 1.4 and HDCP 2.2
• Supports Multiple Color Formats:
 - RGB 8/10/12 bpc; YCbCr4:2:2, YCbCr4:2:0 8/10/12 bpc
 - Supports up to 8-Channel LPCM, compressed audio (AC-3, DTS) and HBR audio formats
 - Supports up to 192Khz audio frame rate and upt o 24-bits audio sample size
• Supports AMD GCN cards, Nvidia® Maxwell cards and Intel® HD 4600 series and newer. Not intended for older architectures.
• Supports AMD Eyefinity feature
• Windows™ and Mac OSX™ compatible
• Apple™ MAC OS X 10.7 up to 10.11
• Windows™ 10(32 & 64 bit)
• Club 3D Mini DisplayPort™ 1.2 Cable to HDMI™ UHD 4K60Hz Active Adapter
• Mini DisplayPort™ 1.2 Male
• HDMI™ Male
• Boxsize: 17.5 x 17.5x 4.5 cm/ 6.89 x 6.89 x 1.77 inch
• Connector Dimensions:
 - Mini DisplayPort™Male: 2.7 x 1.2 x 1 cm / 1.06 x 0.47 x 0.39 inch
 - HDMI Male: 5.5 x 2.1 x 1.3 cm / 2.17 x 0.83 x 0.51 inch
• Cable Length: 3m / 9.84feet
• Cable Weight: 145 gr / 5.11 oz
• Box Weight: 63 gr / 2.22 oz
• Total Weight: 208 gr / 7.33 oz
