Mini DisplayPort to DisplayPort 1.4 HBR3 Cable M/M 2m/6.56ft.
CAC-1115 The Club 3D Mini DisplayPort™ to DisplayPort™14 HBR3 cable enables the connection of your Mini DisplayPort™ supported source device to a monitor or other DisplayPort™ supported device. It features a locking DisplayPort connector providing a secure, dependable connection. Simply press the built-in one- touch latch button to unlock the connector.
This professional grade cable is ceritfied by Vesa.
Maximum resolution: |
Using DSC with HBR3 transmission rates, DisplayPort 1.4 can support up to: |
- 8K @ 60Hz |
- 4K at 144 Hz |
Without compression: |
(DSC) DisplayPort 1.4 can support up to: - 5K @ 60Hz |
Connector 1: Mini DisplayPort™ Male |
Connector 2: DisplayPort™ Male |
Model |
Product Name: Mini DisplayPort™ to DisplayPort™ 1.4 HBR3 8K60Hz Cable Male / Male 2 mtr. / 6.56 Ft. |
Product Series: Accessories |
Weight: 93 gr |
Cable length: 2 meters / 6.56 feet |
Item Code: CAC-1115 |
EAN Code: 8719214470630 |
UPC Code: 841615100811 |
Features |
• Fully DisplayPort™ Version 1.4 Compliant, HBR3, 32.4Gbps |
• Downwards compatible to older Displayport standards |
• Support resolutions up to 8K @ 60Hz and 4K @ 144Hz |
• Bi-Directional |
• Vesa Certified |
Operating System Support: |
All |
