![](banner/600x600/3_1.jpg)
USB 3.2 Gen1 Type A to HDMI™ Dual Monitor 4K60Hz
The Club3D CSV-1474 USB 3.2 Gen1 Type A to HDMI™ Dual Monitor 4K60Hz product allows you to connect 2 Screens at 4K60Hz to any host system with a free USB3.2 Gen1 Type A port. Featuring the next generation DisplayLink DL6950 SOC, your existing Notebook/PC- System/Mac/Tablet, is ready for the future.
HDMI™ 2.0
The Bandwidth for HDMI™ 2.0 was increased to 6Gbps per lane bringing the total bandwidth of the 3 integrated lanes 18Gbps. HDMI™ 2.0 is also referred to as HDMI UHD, meaning it supports Ultra High Resolutions of up to 3840x2160p at 60Hz. HDMI™ 2.0 is downwards compatible to earlier versions however that will influence the max supported resolutions.
In case you need assistance to choose the correct cable, please visit our
website www.club-3d.com or feel free to mail us at [email protected] and it will be our pleasure to assist you.
Check out the downloads tab below for more information
Model |
Product Name: Club 3D USB3.2 Gen1 Type A to HDMI™ 2.0 Dual Monitor 4K 60Hz |
Item Code: CSV-1474 |
EAN Code: 8719214470739 |
UPC code: 841615100910 |
Input |
1x USB A Male |
Output |
2 x HDMI™ 2.0 Female |
• Works on any host System with USB 3.2 Gen1 Type A output |
• Not Downwards compatible to earlier USB versions |
• Compatible with HDMI™ 2.0 Specifications |
• Supported Max. output resolutions : |
- For Dual Screen Setup : 2x 3840 x 2160 @ 60Hz |
- For Single Screen Setup : 4096 x 2160 @ 60Hz |
• Support for HDCP 2.2 |
• Integrated 2.0 Audio and 5.1 Audio |
• Adapt automatically to bandwidth constraints |
• USB Powered, no external power needed |
USB A to HDMI™ 2.0 Dual Monitor 4K 60Hz |
Operating System Support: |
Windows™ and MAC OS compatible |
Please contact us at [email protected] if you require more information. |
Other Info |
• Box size: 13 x 9 x 4.5 cm / 5.2 x 3.6 x 1.8 inch |
• Adapter Weight: 75 gr / 2.7 oz |
• Total Cable length: 30 cm / 11.8 inch |
• Adapter Size : 8 x 6 x 1.6 cm / 3.2 x 2.4 x 0.7 inch |
• Connector dimensions: |
- USB Type A Male: 4 x 0.7 x 1.5 cm / 1.57 x 0.28 x 0.6 inch |
• Box Weight 30 gr / 1 oz |
• Total Weight: 105 gr / 3.7 oz |
- SPECIFICATION_SHEET _CSV-1474_EN.pdf
- SPECIFICATION_SHEET _CSV-1474_DE.pdf
- SPECIFICATION_SHEET _CSV-1474_ES.pdf
- CSV-1474-A5-Quick-Instal-2020.pdf
