USB3.2 Gen1 Type A to DisplayPort™1.2 Dual Monitor 4K60Hz Video Splitter
The Club 3D CSV-1477 a USB3.2 Gen1 Type A to DisplayPort™ 1.2 Dual Monitor 4K 60Hz video splitter. This unique product allows you to connect 2 Screens at 4K 60Hz to any host system with a free USB3.2 Gen1 Type A port. Featuring the next generation DisplayLink DL6950 SOC, your existing Notebook/PC-System/Mac/Tablet, is ready for the future. Become more efficient and accomplish more, with 2 displays delivering 4 K performance, you can have four times the screen space compared to 1080p.
DisplayPort™++
The Club 3D USB3.2 Gen1 Type A to Displayport™ 1.2 Dual Monitor 4K 60Hz splitter has 2 Displayport™++ outputs or in other words, Displayport™ 1.2 Dual Mode. This means the USB3.2 Gen1 Type A to Displayport™ 1.2 Dual Monitor 4K 60Hz is an active device and when converting the video signal to DVI or HDMI™ you must use passive cables or adapters to connect your screen(s).
Product Name: USB3.2 Gen1 Type A to DisplayPort™1.2 Dual Monitor 4K60Hz Video Splitter |
Product Code: CSV-1477 |
EAN code: 8719214470746 |
UPC code: 841615100927 |
• Compatible with Displayport™ 1.2 Dual Mode |
• Supported max output resolutions: |
- 1x 5120 x 2880 at 60Hz (you need 2 cables to connect to monitor) or |
- 2x 4096 x 2160 at 60Hz |
• Integrated 2.0 audio and 5.1 audio |
• Works on any Host System with USB3.2 Gen1 Type A ouput |
• Not downwards compatible to earlier USB versions |
• USB Powered, no external power needed |
• Low latency |
• Pixel-perfect graphics |
• Adapt automatically to bandwidth constraints |
• Compression tuned for video content and high quality graphics |
• Uncompromised 4K/UHD video quality |
• Windows™ and MAC OS compatible |
• CSV-1477 Video Splitter |
• Quick install guide |
Available Interfaces |
• 1x USB A Male |
• 2x DisplayPort™ Female |
• Box size: 11 x 13 x 5.5 cm / 4.33 x 5.12 x 2.16 inch |
• Adapter Weight: 75 gr / 2.7 oz |
• Total Cable length: 30 cm / 11.8 inch |
• Adapter Size: 8 x 6 x 1.6 cm / 3.2 x 2.4 x 0.7 inch |
• Connector dimensions USB Type A Male: 4 x 0.7 x 1.5 cm / 1.57 x 0.28 x 0.6 inch |
• Box Weight 45 gr / 1.58 oz |
• Total Weight: 120gr / 4.23 oz |
- CSV-1477_SPECIFICATION-SHEET_EN.pdf
- CSV-1477_SPECIFICATION-SHEET_DE.pdf
- CSV-1477_SPECIFICATION-SHEET_ES.pdf
- CSV-1477-A5-Quick-Instal-2020.pdf
