USB 3.2 Gen1 Type A to DisplayPort 1.2 Dual Monitor 4K60Hz
CSV-1477 - The Club 3D USB 3.2 Gen 1 to DisplayPort™ 1.2 Dual Monitor 4K 60Hz. This unique product allows you to connect 2 Screens at 4K 60Hz to any host system with a free USB 3.2 Gen 1 port. Featuring the next generation DisplayLink DL6950 SOC, your existing Notebook/PC-System/Mac/Tablet, is ready for the future. Become more efficient and accomplish more, with 2 displays delivering 4 K performance, you can have four times the screen space compared to 1080p.
DisplayPort™++
The Club 3D USB 3.2 Gen 1 to Displayport™ 1.2 Dual Monitor 4K 60Hz has 2 Displayport™++ outputs or in other words, Displayport™ 1.2 Dual Mode. This means the USB A to Displayport™ 1.2 Dual Monitor 4K 60Hz is an active device and when converting the video signal to DVI or HDMI™ you must use passive cables or adapters to connect your screen(s).
DisplayPort 1.2 Cable HBR2 M/M 3m/9.84ft 30AWG
DisplayPort 1.1 to HDMI 4K30Hz VR ready Passive Adapter
Product Name: Club 3D USB 3.2 Type A Gen 1to DisplayPort 1.2 Dual Monitor 4K 60Hz
Item Code: CSV-1477
EAN Code: 8719214470746
UPC Code: 841615100927
Input
USB 3.2 Gen 1 Male
Output
2 x DisplayPort 1.2 Female
- Works on any Host System with USB 3.2 Gen 1 Type A ouput.
- Not downwards compatible to earlier USB versions
- Compatible with DisplayPort™ 1.2 Dual Mode
- Supported max. output resolution up to:
For Single Screen setup: up to 5120x2880p @ 60Hz(you need 2 cables to connect to monitor)
For Dual Screen setup: up to 2 x 3840x2160p @ 60Hz
- Adapt automatically to bandwidth constraints
- Integrated 2.0 audio and 5.1 audio
Voltage
USB powered, no external power needed.
SenseVision USB 3.2 Gen 1 to DisplayPort 1.2 Dual Monitor 4K 60Hz
Quick installation guide.
Operating System Support:
WIN 10 / 8.1
Notes:
-The Club 3D USB 3.2 Gen 1 to Displayport 1.2 Dual Monitor 4K 60Hz has 2 Displayport++ outputs or in other words, Displayport 1.2 Dual Mode. This means the "USB A to Displayport 1.2 Dual Monitor 4K 60Hz" is an ac-tive device and when converting the video signal to DVI or HDMI you must use "passive" cables or adapters to connect your screen(s).
Please contact us at [email protected] if you require more information.
