Thunderbolt 3 to HDMI 2.0 Dual Monitor 4K60Hz M/F
CSV-1574 - The Thunderbolt™ 3 to HDMI™ 2.0 Dual Monitor 4K60Hz lets users easily connect two HDMI™ 2.0 Screens to any device with a Thunderbolt™ 3 interface. This unique adapter is compatible with both Mac OS and Windows™ 10. The output resolution supported is up to [email protected] for Single Screen and Dual Screen setups. It is fully Plug & Play, so no need for driver installation. This stylish adapter has a beautiful Brushed Aluminum Casing making it strong and light.
It is also very slim, 16 mm, making it easy to carry with you.
Multiply your screen area with your tablet, desktop PC or Ultrabook. With multiple monitors your computer will become more useful and you will become more efficient and accomplish more. With 2 displays delivering 4K performance, you can have four times the screen space compared to 1080p.
Important note for Apple M1-chip based computers:
Please note that for Mac Systems based on M1 Architecture the Multi Display function of Thunderbolt 3 is not enabled. This product will not work with the M1 Architecture.
Product Name: |
Thunderbolt™ 3 to HDMI™ 2.0 Dual Monitor 4K60Hz M/F |
Product Code: CSV-1574 |
EAN code: 8719214470746 |
UPC code: 841615100941 |
• Compatible with Thunderbolt™ 3 over USB Type C source |
• Compliant to HDMI™ 2.0 specification |
• Supported output resolution for Single and Dual Screen setup: up to [email protected] / 3840x2160p @ 60Hz |
• Powered thru Thunderbolt™ 3, 15 Watt, no external power needed |
• Plug & Play, no need for driver installation |
• OS Support: Mac OS™ and Windows™ 10 |
• Mac™ OS and Windows™ 10 |
• Thunderbolt™ 3 to HDMI™ 2.0 Dual Monitor 4K60Hz |
Available Interfaces |
• 1x Thunderbolt™ 3 Male |
• 2x HDMI™ 2.0 Female |
• Box size: 32 x 7 x 3.5 cm / 12.6 x 2.76 x 1.38 " |
• Adapter size: (L) x (W) x (H) 113 x 60 x 16 mm / 4.45 x 2.36 x 0.63 " |
• Cable Length: 270 mm / 10.63 " |
• Adapter Weight: 99 gr / 3.49 oz |
• LDP Bag Weight: 6 gr / 0.21 oz |
• Foam Weight: 6 gr / 0.21 oz |
• Box Weight: 42 gr / 1.48 oz |
• Total Weight: 153 gr / 5.40 oz |
Important note for Apple M1-chip based computers: |
Please note that for Mac Systems based on M1 Architecture the Multi Display function of Thunderbolt 3 is not enabled. This product will not work with the M1 Architecture. |
Note: |
- CSV-1574-SPECIFICATION-SHEET_EN.pdf
- CSV-1574-SPECIFICATION-SHEET_DE.pdf
- CSV-1574-SPECIFICATION-SHEET_ES.pdf
- CSV-1574-QUICK INSTALL-GUIDE_EN.pdf
