Displayport to VGA Active Adapter
CAC-1003 The Club 3D is an active DisplayPort™ to VGA signal converter. It accepts DisplayPort™ input from a DisplayPort™ enabled Desktop or Laptop and converts to a legacy analog VGA output allowing the use of analog VGA televisions, monitors and projectors. The adapter offers hassle free plug and play functionality and is powered by the DP output.
The DisplayPort™ interface in the adapter consists of two main lanes for DP data, AUX channel, HPD signal and power. The VGA output is compliant to VSIS standard and supports up to WUXGA RB timings.
The adapter works with AMD, Nvidia and Intel Graphic Solutions.
Model |
Product Name: DisplayPort™ to VGA Active Adapter |
Product Series: Adapter |
Weight: 41 gr |
Cable length: 150 mm |
Item Code: CAC-1003 |
EAN Code: 8719214470784 |
UPC Code: 841615100972 |
Features |
• DisplayPort™ 1.1a compliant receiver offering 5.4Gbps bandwidth over 2 lanes |
• Integrated tripler 10-bit,162MHz video DAC for analog VGA signal output |
• EDID and MCCS pass-through from PC source to display |
• Supports resolutions up to WUXGA 1920x1200p at 60Hz |
• Supports HDTV formats up to 1920x1080p Full HD |
• Powered by the DisplayPort™ output |
• Automatic sink detection |
• Support for multi-monitor setups and AMD Eyefinity |
• Compatible with AMD, Nvidia and Intel Graphics solutions |
Connector 1: |
DisplayPort™ Male |
Connector 2: |
VGA Female |
Operating Systems |
Windows, Apple OS X |
In the Box |
Club 3D CAC-1003 DisplayPort to VGA Active Adapter |
