Mini DisplayPort™ 1.4 Cable to HDMI™ 2.0b HDR Active Adapter Male/Male 2m/6.56 ft.
CAC-1182 - The Club3D CAC-1182 is a Mini DisplayPort™ 1.4 to HDMI™ 2.0b signal converter cable. It features support for HDR Video quality for deep color media content playback. The DisplayPort™ receiver supports up to 5,4 Gbps per lane over 4 lanes. The HDMI™ output is fully compliant to HDMI™ specification version 2.0b.
Supports up to 4K UHD Resolutions
The CAC-1182 supports UHD resolutions up to 4096 x 2160p at 60Hz.
Color Formats
It supports RGB/YCbCr video color formats with a color depth of 16bpc (or 48 bits per pixel) as long as it fits within the DisplayPort™ and HDMI™ link bandwidth. The CAC-1182 also supports pixel encoding conversion from RGB or YCbCr 4:2:2 to YCbCr 4:2:0 and YCbCr 4:2:0 pass-trough function. In addition HDR with deep color up to 12Bpc at 4K 60Hz is supported through the conversion of RGB/YCbCr 4:2:2 over DP link to YCbCr 4:2:0 on the HDMI™ output with a horizontal expansion to CEA timings.
Model: |
Product Name: DisplayPort™ 1.4 Cable to HDMI™ 2.0b HDR Active Adapter Male/Male 2m/6.56 ft. |
Product Series: Cable |
Itemcode: CAC-1182 |
EAN code: 8719214471217 |
UPC code: 841615101405 |
• DisplayPort™ 1.4 Receiver, up to 5.4Gbps link Rate, HBR2/HBR/RBR |
• Video Stream Handling |
- Up to 600Mhz dual pixel path and 16bpc |
- RGB/YCbCr 4:2:2/4:2:0 pixel format |
- Horizontal expansion of Vesa CVT to CEA Timings (as per DP™ 1.4 spec) |
• DisplayPort™ to HDMI™ Stereoscopic 3D Transport |
- Frame Sequential to Stacked Top-Bottom Conversion |
- Pass-trough of ther 3D Formats |
• Audio Stream Handling |
- LPCM and compressed Audio encoding formats |
- Max audio sample rate of 192 Khz x 8 Channel or 768 KHz x 2 Channel |
• HDCP Support |
- HDCP 1.3 to HDCP 1.4 Repeater function |
- HDCP 2.2 to HDCP 1.4 and 2.2 Repeater Fucntion |
• HDMI™ transmitter |
- Compliant to HDMI™ specifications version 2.0b |
- 600MHz max TMDS character clock |
- High Daynamic Range (HDR) support both Static- and Dynamic HDR. |
- CEC Support - snooping, tunneling |
• Max Video resolution and color depth on HDMI™ output |
- 4K 60Hz YCbCr 4:2:2, up to 12bpc |
- 4K 60Hz YCbCr 4:2:0, up to 12bpc |
- 4K 30Hz RGB/YCbCr 4:2:2, up to 12bpc |
Mini DisplayPort™ 1.4 male |
HDMI™ 2.0b male |
Windows 10/8.1, Apple OS X |
• Box size: 145 x 145 x 45mm. |
• Box Weight: 49 gr. |
• Product Weight: 88 gr. |
• Product height: 11mm. |
• Product width: 22mm. |
• Product Length: 2 meter/ 6.56 feet |
• Made in China |
Mini DisplayPort™ 1.4 Cable to HDMI™ 2.0b HDR Active Adapter Male/Male 2m/6.56 ft. |
