USB Type C 3.2 Gen 1 Multi Stream Transport (MST)Hub DisplayPort1.4 Triple Monitor
CSV-1550 - The Club-3D USB Type C 3.2 Gen 1 Multi Stream Transport(MST)Hub DisplayPort™ 1.4 Triple Monitor is an integrated solution that allow you to enjoy displaying content onto three different monitors / displays simultaneously under MST mode. The three screens can accommodate displaying different contents in parallel or by simply extending the existing screen, giving a panoramic view of the content which maximizes the user’s visual experience. With its multi-display capabilities, this hub can serve as a convenient and hassle-free portable, alternative solution to the conventional docking station.
It’s the perfect solution for host devices which feature DP1.2 /1.4 graphic cards that supports all DP Alt mode video signal output, for gaming and commercial applications. Supports G-Sync, FreeSync.The MST Hub is directly powered from the host thru the USB Type C 3.2 Gen 1 connector.
Product Name: USB Type C 3.2 Gen 1 Multi Stream Transport(MST)Hub DisplayPort™ 1.4 Triple Monitor |
Itemcode: CSV-1550 |
EAN code: 8719214471422 |
UPC code: 841615101603 |
• Compliant with DisplayPort™1.4 specification |
• Compliant with HDCP 2.2 specification |
• Supports 1.4 Triple Monitor 4K60Hz with DSC 1.2 |
• Supports dual [email protected] bpp without compression |
• Supports G-Sync, FreeSync and VRR |
• DSC 1.2 transport and up to 4-slice decompression |
• High Dynamic Range (HDR) video |
• SST or up to 3 stream MST |
Microsoft Windows® 10 |
• CSV-1550, USB Type C 3.2 Gen 1 Multi Stream Transport(MST)Hub DisplayPort™ 1.4 Triple Monitor |
Available Interfaces: |
• 1x USB Type C 3.2 Gen 1 for connecting to Host |
• 3x DisplayPort™ Female for connecting to monitors |
• Box size: 14.5 x 14.5 x 4.5 cm |
• Box size: 5.7 x 5.7 x 1.77 inch |
• Device size: 7.9 x 7.9 x 1.7 cm |
• Device size: 3.11 x 3.11 x 0.67 inch |
• Cable to Host : 13 cm / 5.12 inch |
• Device Weight: 58 gr / 2.04 oz |
• LDPE Bag Weight: 5gr/ .17oz |
• Box Weight: 24 gr / .85oz |
• Total Weight: 87 gr / 3.06 oz |
MULTI STREAM TRANSPORT
- SPECIFICATION SHEET_CSV-1550_EN.pdf
- SPECIFICATION SHEET_CSV-1550_DE.pdf
- QUICK-INSTALL-GUIDE-DE-EN-CSV-1550.pdf
