DisplayPort 1.4 Active Repeater 4K120Hz HBR3 F/F
The Club 3D CAC-1007 is a DisplayPort™ 1.4 active repeater, which provides a convenient method for users to extend DP™ signal from host PC to monitor or projector up to 20 meters/65.6 ft (10 meters/32.8 ft in and 10 meters/32.8 ft out) at max 4K120Hz resolution, for 28AWG or above cable.
The Adapter is powered thru an Micro USB to USB Type A cable(provided with the product).
Product Name: DisplayPort™ 1.4 Active Repeater 4K120Hz HBR3 F/F |
Product Series: Adapter |
Itemcode: CAC-1007 |
EAN code: 8719214471590 |
UPC code: 841615101788 |
• Support DP1.4™ and downward compatible with lower versions |
• Transmission speed 1.62 Gbps / 2.7 Gbps / 5.4Gbps / 8.1 Gbps |
• Support DisplayPort™ 1.4 HBR3 with max video resolution [email protected] |
• Extending Distance: max 20m/65.6ft (10m/32.8ft input, 10m/32.8ft output) for 28AWG or above cable, |
• Support cascading function up to 3 levels |
Note: To achieve 8K transmission, the source and display should support DP1.4™, the connected cable spec should be 28AWG or above DP1.4™. |
When using the cascading function to achieve longer distance, the max resolution/refresh will be decreased. |
The repeater is not bidirectional, so make sure to connect the source to the input port and display to the output port. |
Applications: |
• For extending your DisplayPort™1.4, desktop, video converter adaptor, docking station, projector, gaming and display system like TV*, digital signage, VR/AR system. |
• Perfect for Host Devices which are featured with the DP1.4™ graphic card that supports DP™ video signal output for gaming, commercial applications. |
Supported resolutions: |
• Support Max. resolution up to [email protected] |
OS Support: All |
• CAC-1007 Active Adapter |
• Micro USB to USB Type A Cable for external power |
Available Interfaces: |
Input: 1x DP1.4™ (Female) + 1x Micro USB to USB Type A Cable for power |
Output: 1x DP1.4™ (Female) |
• Box size: 10 x 10 x 3.5 cm / 3.94 x 3.94 x 1.38 inch |
• Adapter size: 6.6 x 2.5 x 1.3 cm / 2.6 x 0.98 x 0.52 inch |
• USB Cable Weight: 28 gr / 1 oz |
• Box Weight: 18 gr / 0.63 oz |
• Adapter Weight 17 gr / 0.6 oz |
• Total Weight 63 gr / 2.23 oz |
* Please update your TV Firmware to the version which supports these resolutions/refresh rates ! |
** Please update your Graphic drivers on your PC and make sure that DSC1.2 is supported on your devices to support the these resolutions/refresh rates! |
*Please use one of our Extension/Adapter cables to connect to your devices |
In case you need assistance to choose the correct cable, please visit our website www.club-3d.com or feel free to mail us at [email protected] and it will be our pleasure to assist you. |
- CAC-1007_SPECIFICATION-SHEET_EN.pdf
- CAC-1007_SPECIFICATION-SHEET_DE.pdf
- CAC-1007_SPECIFICATION-SHEET_ES.pdf
