USB 3.2 Gen2 Type A Extension Cable 10Gbps M/F 5m/16.40ft
The Club 3D CAC-1411 is an USB Type A extension cable for extending and enhancing USB Signal up to 5m / 16.4 ft. It is compatible with USB 3.2 Gen 2 with a maximum of 10Gbps data transmission. Its downward compatible with lower versions, please note that specifications will be limited to the device connected.
Product Name: |
USB 3.2 Gen2 Type A Extension Cable 10Gbps M/F 5m/16.40ft |
Product Series: Cable |
Product Code: CAC-1411 |
EAN code: 8719214471675 |
UPC code: 841615101887 |
• USB Type A Male 1 Connector ( Connect USB A to Host , PC or mobile device ) and USB A Female 1 Connector ( Connect to USB Device ) |
• Compatible with USB 3.2 Gen2 with a maximum of 10Gbps data transmission, downward compatible with lower versions (USB 3.1/USB3.0/USB2.0) |
• Support a maximum of 5 meters or 16.40 feet distance |
• Supports a maximum of 900mA downstream charging |
• USB Bus Powered no external power required |
• Uni-Directional from Male to Female only |
NOTE: To achieve a maximum of 10Gbps bandwidth, both the USB Host and the USB Device must support 10Gbps of data transmission |
OS Support: All |
• USB 3.2 Gen2 Type A Extension Cable 10Gbps M/F 5m/16.40ft |
Available Interfaces |
• USB 3.2 Gen2 Type A Male |
• USB 3.2 Gen2 Type A Female |
• Box size: 17.5 x 17.5 x 4.5 cm / 6,89 x 6,89 x 1,77 inch |
• Output Cable length approx.: 5m / 16.40ft |
• Connector dimensions: |
- USB Type A Male: 4.3 x 1.6 x 0.8 cm / 1.69 x 0.63 x 0.31 inch |
- USB Type A Female: 5.05 x 2.25 x 1.15 cm / 2.16 x 0.89 x 0.45 inch |
• Cable Weight: 182 gr / 6.42 oz |
• Box Weight: 63 gr / 2.22 oz |
• LDPE Bag Weight: 8 gr / 0.28 oz |
• Total Weight: 253 gr / 8.93 oz |
- CAC-1411_SPECIFICATION-SHEET_EN.pdf
- CAC-1411_SPECIFICATION-SHEET_DE.pdf
- CAC-1411_SPECIFICATION-SHEET_ES.pdf
