USB4 Type-C Gen3x2 Bi-Directional Cable 40Gbps 8K60Hz 100W PowerDelivery M-M 0.8m - 2.62ft
The Club 3D CAC-1571 NEW Generation of USB4™ Cable Technology is providing faster data performance, a better charging experience, the convenience of interoperability and certified reliability.
Key characteristics of the USB4™ solution include two-lane operation and up to 40Gbps operation over 40Gbps-certified cables. Multiple data and display protocols to efficiently share the total available bandwidth over the bus.
Product Name: |
USB4™ Type-C Gen3x2 Bi-Directional Cable 40Gbps 8K60Hz 100W PowerDelivery M/M 0.8m / 2.62ft |
Product Series: Cable |
Product Code: CAC-1571 |
EAN code: 8719214471767 |
UPC code: 841615101993 |
• Full-featured USB4™ Type-C Certified Cable (USB4™ Gen3x2) |
• Bandwidth up to 40Gbps |
• Power Delivery up to 100W |
• E-mark IC |
• Cable length 0.8 m / 2.6 ft |
• Support more protocols, DisplayPort™ and PCI express |
• Type-C cable ONLY |
• Backwards compatible with USB3.2, USB2.0 and Thunderbolt™ 3 |
• USB-IF Certified |
• All |
• USB4™ Type-C Gen3x2 Bi-Directional Cable 40Gbps 8K60Hz 100W PowerDelivery M/M 0.8m / 2.62ft |
Available Interfaces |
• 1x USB4™ Type-C Male |
• Box size: 14.5 x 14.5 x 4.5 cm / 5,71 x 5,71 x 1,77 inch |
• Connector size: (L) x (W) x (H) 3.37 x 1.22 x 0.64 cm / 1.33 x 0.48 x 0.25 inch |
• Cable Length: 0.8 m/ 2.62 ft |
• Cable Weight: 73 gr / 2.58 oz |
• LDP Bag: 6 gr / 0.21 oz |
• Box Weight: 46 gr / 1.62 oz |
• Total Weight: 125 gr / 4.41 oz |
2013 USB 3.1 Gen 2 Super Speed + SS+ 10Gbps SS/HS/FS/LS
- CAC-1571_SPECIFICATION-SHEET_EN.pdf
- CAC-1571_SPECIFICATION-SHEET_DE.pdf
- CAC-1571_SPECIFICATION-SHEET_ES.pdf
