The Club 3D CAC-1571 NEW Generation of USB4™ Cable Technology is providing faster data performance, a better charging experience, the convenience of interoperability and USB-IF Certified reliability.
Key characteristics of the USB4™ solution include two-lane operation and up to 40Gbps operation over a 40Gbps - certified cable . Multiple data and display protocols to efficiently share the total available bandwidth over the bus.
USB Gen 2 Type C Active Optical Cable A/V Unidirectional M/M  20 m/ 65.62 ft
USB 3.2 Gen2 Type C to C Active Bi-directional Cable 8K60Hz  M/M 5m/16.4ft
USB Type-C Gen 2 Active Cable 4K60Hz 10Gbps PD 100W M/M 1 m/ 3.28 ft
USB4™ Type-C Gen3x2 Bi-Directional USB-IF Certified Cable 40Gbps 8K60Hz 100W PowerDelivery M/M 0.8m / 2.6 ft
Product Series: Cable
Product Code: CAC-1571
EAN code: 8719214471767
UPC code: 841615101993
• Full-featured USB4™ Type-C Cable (USB4™ Gen3x2) USB-IF Certified
• Bandwidth up to 40Gbps
• Power Delivery up to 100W
• E-marker IC
• Cable length 0.8 m / 2.62 ft
• Support more protocols, DisplayPort™ and PCI express
• Type-C cable ONLY
• Backwards compatible with USB3.2, USB2.0 and Thunderbolt™ 3
• USB-IF Certified
• USB4™ Type-C Gen3x2 Bi-Directional USB-IF Certified Cable 40Gbps 100W PowerDelivery M/M 0.8m / 2.62 ft
• 1x USB4™ Type-C Male
• Box size: 14.5 x 14.5 x 4.5 cm / 5,71 x 5,71 x 1,77 inch
• Connector size: (L) x (W) x (H) 3.37 x 1.22 x 0.64 cm / 1.33 x 0.48 x 0.25 inch
• Cable Length: 0.8 m/ 2.62 ft
• Cable Weight: 73 gr / 2.58 oz
• LDP Bag: 6 gr / 0.21 oz
• Box Weight: 46 gr / 1.62 oz
• Total Weight: 125 gr / 4.41 oz
