USB3.2 Gen1 Type-C to Gigabit Ethernet Adapter M/F
The Club 3D CAC-1519 is an USB3.2 GEN1 Type-C to Gigabit Ethernet Adapter. It enables your new MacBook Pro, ChromeBook or other USB-C supported host PC to get access to a fast Ethernet network by connecting the Gigabit Ethernet port. The Ethernet adapter is compact and highly portable. Powered by the USB C port, the adapter requires no external power and is ideal for use with notebooks and Ultrabooks.
Reliable and fast connection
The USB3.2 GEN1 Type-C to Gigabit Ethernet adapter gives you direct, wired access to a fast ethernet network at places where a wireless connection is slow, inconsistent or not available at all. Benefit from the reliability and speed a wired Ethernet connection offers for online gaming, downloading large files or streaming high resolution media.
The USB3.2 GEN1 Type-C to Ethernet Adapter supports all USB3.2 GEN1 Type-C devices.
USB 3.2 Gen1 Type C to Gigabit Ethernet Active Adapter
USB 3.2 Gen1 Type-A to RJ45 2.5Gbps Adapter M/F
USB 3.2 Gen1 Type C to RJ45 2.5Gbps Adapter
Product Series: Adapter
Product Code: CAC-1519
EAN code: 8719214471811
UPC code: 841615102044
• Supports USB-C and Gigabit Ethernet port
• Supports USB-C plug and play, hot swap
• No extra driver software is required, and auto driver installation
• Supports 10/100 /1000Mbps bandwidth
• Supports USB3.2 Gen1, USB 2.0 and USB 1.1 ( When using lower USB versions the ethernet speed will be affected )
• Supports twisted pair crossover detection and auto-correction
• USB bus power (no external power supply)
• Windows and Mac OS
• USB3.2 Gen1 Type-C to Gigabit Ethernet Adapter
• USB Type-C male
• RJ45 Ethernet female
• Boxsize: 6 x 24 x 3.5cm/ 2.36 x 9.45 x 1.38"
• Cable length: ± 19.7 cm / 7.77"
• USB C Connector Dimensions: 3.7 x 1.2 x 0.64 cm / 1.46 x 0.98 x 0.25"
• Adapter Dimensions: 6 x 1.6 x 2.7 cm / 2.36 x 0.63 x 1.06"
• Adapter Weight: 24 gr./ 0.85 oz
• Box Weight: 29 gr / 1.02 oz
• LDPR Bag: 3 gr / 0.11 oz
• Total Weight: 56 gr/ 1.98 oz
