USB 3.2 Gen1 Type-A to Micro USB Cable M/M 1m /3.28ft
CAC-1408 - The Club 3D USB 3.2 Gen1 Type-A to Micro USB Cable enables the connection of your existing USB Type A output connections, Laptops, tablets and Ultrabooks, Power Chargers, etc. to Micro USB inputs, like camera's, Phones and our range of extension cables and adapters.
The cable is backwards compatible and supports USB 3.0 and USB 2.0 as well. The USB 3.2 Gen1 specification ensures a bitrate of 5Gbps for transfer of large files.
Product Name: |
USB 3.2 Gen1 Type-A to Micro USB Cable M/M 1m /3.28ft |
Product Series: Cables |
Product Code: CAC-1408 |
EAN code: 8719214471880 |
UPC code: 841615102099 |
• Connect USB type A to Micro USB enabled devices |
• USB3.2 Gen1 data transfer rates up to 5Gbps when used with USB 3.2 Gen1 host and device |
• Backwards compatible to support USB 3.0 and USB 2.0 specification. |
• This cable is Bi-directional |
• Supports both data and power |
• Maximum Power output (PD profile 1) up to 2.4A |
• All |
• 1x USB 3.2 Gen1 Type-A to Micro USB Cable |
Available Interfaces |
• USB Type A Male |
• Micro USB Male |
• Bagsize: 8.5 X 7.5 x 0.001cm/ 3.35 x 2.95 x 0.0004" |
• Bag Weigth: 5 gr/ 0.14 oz |
• Cable Length: 1m / 3.28 ft |
• Cable Weight: 26 gr/ 0.95 oz |
• Total Weight: 31 gr/ 1.09 oz |
2013 USB 3.1 Gen 2 Super Speed + SS+ 10Gbps SS/HS/FS/LS
- CAC-1408_SPECIFICATION-SHEET_EN.pdf
- CAC-1408_SPECIFICATION-SHEET_DE.pdf
- CAC-1408_SPECIFICATION-SHEET_ES.pdf
