Power Charger, 4 ports, 2x USB Type-A   2x Type-C up to 112W, Power Delivery(PD) Support
The Club3D CAC-1904 Power Charger, 4 ports, 2x USB Type-A + 2x Type-C  up to 112W, Power Delivery(PD) Support is designed for users who want to use only 1 Power Charger for their PC/Laptop/Tablet/Mobile phone as well as their docking station. It has a separate power cord for use into a wall socket. The Power Charger is light weight without compromising on Quality and safety. By adopting Power Delivery(PD) charging technology, this versatile Power Charger provides you with Both charging function through 2 times USB Type-A + 2x USB Type-C interface, you can charge any connected Mobilephone / Tablet / NoteBook. Furthermore all it needs is a free USB Type A and/or Type C port on your  Dock/NoteBook/Tablet/ Mobile phone to be charged via the bundled USB cable.
Charging: By adopting PD Charging technology and charging function through both USB Type-A and Type-C interfaces the Club3D Power Charger offers versatile and unique functionality with its 4 ports. It will charge your devices up to 112 Watts. Built-in safeguards protect your devices against excessive current, overcharging and overheating.
USB TYPE C POWER CHARGER UP TO 27W
USB Type A and C Dual Power Charger up to 60W
USB Type A and C Power Charger, 5 ports up to 111W
Product Code: CAC-1904
EAN code: 8719214472023
UPC code: 841615102259
• Internal chip allows an input voltage of 100-240VAC 50/60Hz
• 112W of output power in total:
Output Single Port
   C1: 5.0V/9.0V/12.0V/15.0V ≤ 3A, 20V≤5.0 A Max. 100W
   C2: 5.0V/9.0V/12.0V/15.0V ≤ 3A, 20V≤5.0 A Max. 100W
   USBA1: 5V ≤ 2.4A
   USBA2: 5V ≤ 2.4A
Output Four Ports
   C1+C2: 5.0V/9.0V/12.0V/15.0V ≤ 3A, 20V ≤ 2.5 A Total Max. 100W
   USBA1+USBA2: 5V ≤ 2.4A Total 12W Max.
• Power Delivery(PD) Support
• Accurate limited current output and over current protection.
• Overload protection and over voltage protection.
• Short circuit protection.
• Over temperature protection and remove the fault conditon auto-recovery.
• Compliant with CE, FCC standards.
• Selected precision electrical components, fire line version.
• Ligth weigth and convenient to use.
• Specially designed for your Type-C supported devices.
• All
• CAC-1904 Power Charger,
Input: 100-110/240VAC, Output: up to 112W, Power Delivery(PD) Support Various Powercords depending on Country (Specify on order)
• 1x RED (Power ONLY)USB Type C cable(1 m / 3.28 ft) for connecting to Host
• 1x Seperate stand
• 1x Mains connector (Specify on Order)
• 2x USB Type-C Female
• 2x USB Type-A Female
• Box size: 17.5 x 17.5 x 4.5 cm / 6.89 x 6.89 x 1.77"
• Device size: 9.85 x 8 x 3 cm / 3.87 x 3.15 x 1.18"
• USB (Power) Cable length approx.: 1 m / 3.28 ft
• Device Weight: 333 gr / 11.74 oz
• Stand Weight: 25 gr / 0.88 oz
• USB Cable Weight: 35 gr / 1.2 oz
• Box Weight: 63 gr / 2.22 oz
• LDPE Bag Weight: 9 gr / 0.3 oz
• Total Weight(depending on PowerPlug) approx.: 546 gr / 19.26 oz
Warning Safe Usage: Only to be used at altitude 2000 meters/6562 feet and below.
