USB TYPE C POWER CHARGER UP TO 27W
CAC-1901 - The Club3D USB Type C Power Charger, with the USB Type C connector is designed for users who need to charge their PC/NoteBook/Tablet/Mobile Phone and/or docking station. It has an integrated AC connector for direct use into a wall socket. The Power Charger is light weight without compromising on Quality and Safety. By adopting PowerDelivery charging technology, the charging function through USB Type C interface, you can charge any USB C powered device. Furthermore all it needs is a free USB Type C port on your PC/NoteBook/Tablet/Mobile phone via the bundled USB cable.
Charging
By adopting PD Charging technology and charging function through USB Type C interface the Club3D USB Type C Power Charger offers unique functionality. It will charge your device up to 27Watts. By using Qualcomm 4+ charging function battery life is protected by avoiding overheating while charging - this function is available by selected devices. It can charge from 0 to 50% in 15 minutes.
Product Name: USB Type C Wall Power Charger up to 27W |
Itemcode: CAC-1901 |
EAN code: 8719214471330 |
UPC code: 841615101528 |
• Multi/purpose-Efficient-Light Weight- Single Port Power Charger |
• Supports USB Type C PD charging function for up to 27W |
• Bundled with a USB Type C (power) connection cable |
• Removes the need for multiple Power Chargers |
• Simple installation |
• Integrated mains connector (country specific version) |
• 1x Output port: USB Type C port |
• Support PD Charging 3V-9V/3A, 9V-11V/2.45A up to 27W Support Qualcomm 4+ Quick Charge function |
• Meets ROHS, FCC and CE EMI requirements |
OS Support: All |
• CAC-1901 Power Charger with integrated mains connector and USB Type C connector |
• USB-Type C cable for connection between Device and Power Charger |
• AC power plug |
• USB Type C Female |
• Box size: 11 x 11 x 5.5 cm |
• Box size: 4.3 x 4.3 x 2.22 inch |
• Device size: 10,2 x 2.54 x 6 cm |
• Device size: 4 x 1.2 x 2.36 inch |
• Device Weight:depending on power plug ≈ 145gr. / 5,11 oz. |
• USB C cable Weight: 35 gr. / 1,2 oz. |
• Box Weight: 40 gr. / 1.41 oz.depending on power plug ≈ 164 gr./ 5.78 oz. |
