HDMI to USB Type-C 4K60Hz Active Cable M/M 1.8m/6 ft
The Club 3D CAC-1334 is a HDMI™ to USB-C Active Cable which allows you to transmit signal from HDMI™ source (Laptop, tablet, PC etc.) to USB-C display devices(TV, monitor, projector, etc.). This cable is Uni-Directional it only works from an HDMI™ Source device to an USB C DP™ 1.2 Alternate mode supported display. This product supports DP™1.2 specification with resolution up to 4096 x 2160@60Hz.
Please make sure your display device is capable of providing at least 5V - 500 mA.
HDMI to DisplayPort 4K60Hz M/F Active Adapter
HDMI to USB C 4K60Hz Active Adapter M/F
HDMI™ to USB Type-C 4K60Hz Active Cable M/M 1.8m/6 ft
Product Series: Cable
Product Code: CAC-1334
EAN code: 8719214472054
UPC code: 841615102280
This product has many features that enable it to perform in a superior manner. Among those features you will find:
• Support HDMI™ input, USB-C output with max 4K/60Hz
HDMI™:
• Support 8/10/12-bit Deep color
• Support HDCP1.4/2.2
• Support Status and Control Data Channel (SCDC)
• Support Resolution up to 4Kx2K@60Hz for 4:4:4 format
USB-C:
• Support DP 1.2 specification
• Support Four Lanes with 1.62Gbps (RBR), 2.7Gbps (HBR) or 5.4Gbps (HBR2) Data Rate per lane
• Support 8/10/12-bit Deep Color
• Support Hot-Plug Detect
• Powered thru USB Type-C at 5V/ 500mA Max.
• All
• CAC-1334 HDMI™ to USB Type-C 4K60Hz Active Cable M/M 1.8m/6 ft
• HDMI™ Male
• USB Type-C Male
• Box size: 14.5 x 14.5 x 4.5cm/ 5.71 x 5.71 x 1.77"
• Total Length: 1.8m/6 ft"
• Connector dimensions:
- HDMI™ Connector: 5.7 x 2.1 x 1.1 cm / 2.24 x 0.83 x 0.43"
- USB Type-C: 3.16 x 1.24 x 0.63 cm / 1.25 x 0.49 x 0.25"
• Cable Weight: 62 gr / 2.19 oz
• Box Weight: 45 gr / 1.59 oz
• LDPE Bag Weight: 8 gr / 0.28 oz
• Total Weight: 115 gr/ 4.06 oz
Note:
- ‑Please update your Graphic drivers on your PC and make sure that DSC1.2 is supported on your devices to support the these resolutions/refresh rates!
