USB Gen1 Type-C Extension Cable 5Gbps 60W(20V/3A) 4K60Hz M/F 1m/3.28ft
The Club 3D CAC-1531 USB Gen1 Type-C Extension Cable 5Gbps 60W(20V/3A) 4K60Hz M/F 1m/3.28ft connects your Notebook, Tablet or Phone with USB Type-C output to your favorite existing Peripherals, Accessories and Chargers. It enables Video, Data and Power over a single cable and both ways. This cable supports USB Gen1 Video up to 4K60Hz, data up to 5Gbps and up to 60Watt(20V/3A) output for Downstream charging or powering your Notebook, Tablet or Smartphone.
USB 3.2 Gen2 Type C to C Active Bi-directional Cable 8K60Hz  M/M 5m/16.4ft
USB Type C to DisplayPort 1.4 8K60Hz HBR3 Active Adapter
Product Series: Cables
Product Code: CAC-1531
EAN code: 8719214472160
UPC code: 841615102402
• USB Gen1 Video, Data and Charging through a single extension cable
• USB Power, max. 60Watt(20V3A) Downstream charging
• Supports up to 4K60Hz
• USB Gen1 Data up to 5Gbps
• Works with all USB Type-C enabled devices
• Reversible USB Type-C connector Male/Female
• Fully Bidirectional
• All
• CAC-1531 USB Gen1 Type-C Extension Cable 5Gbps 60W(20V/3A) 4K60Hz M/F 1m/3.28ft
• USB Type-C Male
• 1x USB Type-C Female
• Box size: 14.5 x 14.5 x 4.5 cm / 5.71 x 5.71 x 1.77"
• Total Cable length approx.: 1 m/ 3.28 ft
• USB Type-C Male Connector dimensions: 4.3 x 1.2 x 0.63 cm / 1.43 x 0.47 x 0.25"
• USB Type-C Female Connector dimensions: 3.77 x 1.2 x 0.8 cm / 1.48 x 0.47 x 0.32"
• Cable Weight: 35 gr / 1.24 oz
• Box Weight: 45 gr / 1.59 oz
• Total Weight: 80 gr / 2.83 oz
