DisplayPort to VGA Cable M/M 2m/6.56ft 28AWG
The Club 3D CAC-1012  DisplayPort™ to VGA Cable M/M 2m/6.56ft 28AWG links any DisplayPort™-equipped desktop, laptop or adapter to a monitor, display, beamer or projector with a 15-pin VGA Female port. Ideal for at home or work, the cable creates a reliable connection for anything from gaming to video projection and supports up to Full HD 1080p(max. resolution of  1920 x 1080). A Micro USB port is also provide for External Power. This quality DisplayPort™ to VGA cable provides superior performance thanks to the combined effect of its Gold plated connectors and 28 AWG conductors. Internal shielding provides reduced crosstalk, suppresses noise, and helps prevent electromagnetic interference (EMI) and radio frequency interference (RFI).Experience a reliable, high-quality connection with this convenient DisplayPort™ to VGA 2m/6.56ft cable.
USB Gen1 Type-C Triple Display Dynamic PD Charging Dock with 65 Watt PS
USB Gen1 Type-C 9-in-1 hub with HDMI, VGA, 2x USB Gen1 Type-A, RJ45, SD/Micro SD card slots and USB Gen1 Type-C Female port
Product Series: Cable
Product Code: CAC-1012
EAN code: 8719214472207
UPC code: 841615102440
• Standard DisplayPort™ Male to 15-pin VGA Male cable
• No External Power needed
• Gold-plated connectors
• Shielded for EMI/RFI interference
• Resolution up to 1920 x 1080 (Full HD 1080p)
• All
• CAC-1012
• DisplayPort™ Male
•VGA Male
• Box size: 14.5 x 14.5 x 4.5 cm / 5.71 x 5.71 x 1.77"
• Cable length: 2m/6.56ft
• DisplayPort™Connector dimensions: 4.7 x 2 x 1.3cm / 1.85 x 0.79 x 0.51"
• VGA Connector dimensions: 4.4 x 3.3 x 1.6 cm / 1.73 x 1.3 x 0.63"
• Cable Weight: 98 gr / 3.46 oz
• Box Weight: 45 gr / 1.59 oz
• Total Weight: 143 gr / 5.05 oz
