Product Name: |
HDMI™ KVM Switch for Dual HDMI™ 4K 60Hz |
Product Code: CSV-1382 |
EAN code: 8719214472245 |
UPC code: 841615102464 |
Eigenschaften: |
• Support resolution up to [email protected] |
• Support RGB 4:4:4/ YCbCr 4:4:4/ YCbCr 4:2:2/ YCbCr 4:2:0 |
• Support KVM function |
• Support a HDMI™ display and a set of Keyboard and Mouse to control two PCs with HDMI™ ports |
• Support 6Gbps per channel (18Gbps all channels) bandwidth |
• Support 12bit per channel (36bit all channels) deep color |
• Support HDCP 2.2/1.4 |
• Support 3D |
• Support HDR |
• Support infrared remote control function |
• Support for switching LED indications |
Supported resolutions: |
• Max Resolution: 3840*[email protected], 4096*[email protected] |
• Windows/Linux/Apple Mac OS |
• CSV-1382 HDMI™ KVM Switch x 1 |
• External Power Supply 5V 3A x 1 |
• IR Remote Control x1 |
• IR Extender x1 |
• USB Type B Male to USB A Male cable x2 |
• Quick Installation Guide |
Available Interfaces |
• PC 1: HDMI™ + USB + Mic + Stereo Port |
• PC 2: HDMI™ + USB + Mic + Stereo Port |
• 3.5mm Mic Input port |
• DC 5V - Power Supply Unit |
• 1x HDMI™ Female |
• 1x MIC |
• 1x Stereo Jack |
• 1x USB Mouse connection |
• 1x USB Keyboard connection |
• 3.5mm Stereo port |
• Box size: 23 x 21 x 6.5 cm / 9.05 x 7.08 x 2.56" |
• Device size: 17.8 x7.5 x 2.6 cm/ 7.0 x 2.95 x 1.02" |
• Box Weight: 147 gr / 5.185 oz |
• Device Weight: 365 gr / 12.875 oz |
• USB Type B Male cable Weight: 54 gr / 1.91 oz - 2x 108 gr / 3.81 oz |
• IR Remote Control incl. battery Weight: 16 gr / 0.57 oz |
• IR Extender Weight: 33 gr / 1.16 oz |
• Power Adapter Weight: 107 gr / 3.77 oz |
• LDPE Bag Weight: 6 gr / 0.21 oz |
• Total Weight: 783 gr / 27.62 oz |
