3 to 1 HDMI™ 8K60Hz/4K120Hz Switch
The Club 3D CSV-1381 is a 3 to 1 HDMI™2.1a spec. Switch that routes your high-definition video and digital audio from any one of the HDMI™ inputs to an 8K60Hz/4K120Hz HDMI™ output. The easiest way of connecting your High-Resolution game consoles and/or your PC/Laptop to 1 High-Resolution HDMI™ display up to 8K60Hz or 4K120Hz. All inputs are capable to accommodate up to 8K60Hz/4K120Hz high-definition video sources simultaneously. The output sends the high-definition audio/video signals to a high definition(8K60Hz) HDMI™2.1a spec. Display. Switching inputs can be done by key pressing, on the unit itself, or with an IR remote unit for easy switching. This is a high-performance and small-sized HDMI™ 8K Switcher in a metal housing with an external Power Supply of 100-240VAC / 5V-1A DC. It's an ideal assistant both at home and at work.
CSV-1381 QUICK INSTALLATION GUIDE
HDMI [email protected] UHD Splitter 4 Ports
HDMI KVM SWITCH FOR DUAL HDMI 4K 60Hz
Product Code: CSV-1381
EAN code: 8719214472719
UPC code: 841615102952
• Support video resolution up to 8K60Hz(7680*4320) or 4K120Hz(3840*2160)
• Support Full 3D
• HDCP 2.2&1.4 pass through
• Support EDID bypass
• HDR support
• Support HDMI™2.1a specifications
• RGB / YCbCr 4:4:4 /YCbCr 4:2:2/YCbCr 4:2:0
• IR remote unit(38KHz)
• Each Input- and Output- cable length is max. 2m/6.56ft
• All
• Club 3D CSV-1381 3 to 1 HDMI™ 8K60Hz Switch
• IR Remote controller (incl CR2025 Battery)
• Power Supply 100-240VAC/ 5V1A DC(Please Specify Plug type when ordering)
• QR Code for downloading the Quick Install Guide (QIG)
• 3x HDMI™ Female
• 1x HDMI™ Female
• Box size: 14.5 x 14.5 x 5.5 cm / 5.7 x 5.7 x 2.17"
• Switch size: 8 x 5.12 x 2 cm / 3.15 x 2.016 x 0.79"
• IR Remote Controller size : 4 x 8.67 x 0.64 cm / 1.58 x 3.41 x 0.25"
• Box Weight: 67 gr / 2.36 oz
• ProductWeight: 105gr / 3.7 oz
• IRRemote Controller weight: 17 gr / 0.6 oz
• Power Supply Weight: 51-112 gr / 1.8-3.95 oz (Depending on PowerPlug)
• Total Weight: 240-301gr / 8.47-10.61 oz (Depending on PowerPlug)
Note:
