Product Name: |
USB Gen1 Type-C 7-in-1 hub with 2x HDMI™, 2x USB Gen1 Type-A, 1x RJ45, 1x 3.5mm Audio, 1x USB Gen1 Type-C 100W Female port |
Product Series: Docking |
Product Code: CSV-1595 |
EAN code: 8719214472269 |
UPC code: 841615102501 |
• Support DP™1.4 Alt mode |
• Support HDMI™ max 4K@60Hz from the USB Type-C Display Alternate Mode function |
• Support HDMI™ max 4K@30Hz from the integrated chipset in the dock - make sure to install the driver from our website at www.club-3d.com |
• Support HDCP1.4, HDCP 2.2 ( on the HDMI with AltMode Function only) |
• Support dual displays for Mac M1/M2 users.* |
• Max 5Gbps data transmission per USB Gen1 Type-A port |
• Support max 7.5W(5V/1.5A) downstream charging, |
2 USB Gen1 Type-A BC 1.2 |
• Support Gigabit Ethernet 10M/100M/1000M, RJ45 |
• Support Audio output |
• Support 1x USB Type C Female PD3.0 with max 100W PD charging and Gen1 5Gbps of data transfer |
NOTE: Please make sure your host supports DP™1.4 Alt mode |
* For Mac OSX users please download driver from the CSV-1595 product page at our website. |
• All |
• 1x USB Gen1 Type-C 7-in-1 hub with 2x HDMI™, 2x USB Gen1 Type-A, 1x RJ45, 1x 3.5mm Audio, 1x USB Gen1 Type-C 100W Female port |
• 1x Quick Install Guide (QIG) |
Available Interfaces |
• USB Gen1 Type-C Male (Connect to host) |
Note: To get max bandwidth, the host should support DP™1.4 Alt mode |
Output: Single and Dual displays |
• 1x HDMI™ |
Support max 4K@30Hz |
Support 8/10 bit color depth output |
Support output pixel format RGB/YCbCr4:4:4/YCbCr4:2:2 |
• 1x HDMI™ Alt Mode |
Support max 4K@60Hz |
Support HDCP 2.2 |
Note: The max resolution of the display determined by the computer and the monitor |
• 2x USB Gen1 Type-A |
Max 5Gbps data transmission per port |
Support max 7.5W(5V/1.5A) downstream charging |
Support short-circuit, over-current, over-voltage protection |
• 1x RJ45 |
Support Gigabit Ethernet, 10M/100M/1000M |
Light indicator indicates the state, no light when no Internet connected, orange light turns on when network connection is established, green light flashes when transmitting data |
• 1x 3.5mm Audio jack |
Support Mic in with digital audio max 48K/16bit sampling rate |
• 1x USB Gen1 Type-C Female (for PD Charging) |
Support max 100W PD charging |
Support PD3.0 Fast Role Swap |
Support Gen 1 - 5Gbps of data transfer |
• Box size: 21 x 21 x 3.5 cm / 8.27 x 8.27 x 1.38" |
• Cable length: ± 25 cm / ± 9.84" |
• Total length: ± 39 cm / 15.35" |
• Hub dimensions: 14 x 6.5 x 1.9 cm / 5.51 x 2.56 x 0.75" |
• Product Weight: 210 gr / 7.41 oz |
• Box Weight: 70 gr / 2.47 oz |
• LDPE Bag Weight: 6 gr / 0.21 oz |
• Total Weight: 286 gr / 10.09 oz |
Note: |
- ‑Please update your Graphic drivers on your PC and make sure that DSC1.2 is supported on your devices to support the these resolutions/refresh rates! |
