USB Gen1 Type-C, 6-in-1 Hub with HDMI 8K30Hz-4K120Hz, 2xUSB Type-A, RJ45 and 2xUSB Type-C, Data and PD charging 100 watt
The Club 3D CSV-1596 is a USB Gen1 Type-C, 6-in-1 Hub with HDMI™8K30Hz-4K120Hz, 2xUSB Type-A, RJ45 and 2xUSB Type-C, Data and PD charging 100 watt, providing an ideal solution for extending the port of Type-C/Thunderbolt host (PC/Laptop/Mobile phone,etc.), especially for those host with a single Type-C port. This hub adopts the latest DP1.4 Alt mode supported IC, enabling to output HDMI™ video with max. 8K30Hz-4K120Hz and at the meanwhile transfer USB 3.1 data with max 5Gbps. The USB Type-A and Type-C data ports allow you to connect 4 USB devices simultaneously. 1 Gigabit Ethernet for super fast Ethernet. Besides, the Type-C female supports PD 3.0 PD Charging 100W (15W is dedicated to the functioning of this product, the rest power(max 85W) will be passed to charge for the host. This 6-in-1 Hub will work on all DP Alt mode supported Type-C hosts.
CSV-1596 QUICK INSTALLATION GUIDE | CSV-1596 QUICK INSTALLATION GUIDE |
Product Name: |
USB Gen1 Type-C, 6-in-1 Hub with HDMI™8K30Hz-4K120Hz, 2xUSB Type-A, RJ45 and 2xUSB Type-C, Data and PD charging 100 watt |
Product Series: Docking Station |
Product Code: CSV-1596 |
EAN code: 8719214472344 |
UPC code: 841615102594 |
• Upstream USB Type-C Female: |
- Support DP1.4 Alt mode |
- Support HBR3 |
- Support DSC1.1/1.2a or uncompressed video |
- Support DSC 1.1/1.2a decoder |
- Support 8/10/12 bit color depth |
- Support pixel format RGB/YCbCr4:4:4/YCbCr4:2:2/YCbCr4:2:0 |
- Support positive and negative connection |
• Downstream HDMI™ Female: |
- Support HDMI™ max 7680*4320@30HZ |
- Support HDMI™ max 4196(3840)x2160@120Hz |
- Support Dynamic HDR10+ |
- Support HDCP1.4&HDCP2.3 specification |
- Support HPD |
- Support 8/10/12 bit color depth output |
- Support 1 to 32 channels LPCM 192kHz audio output |
- Supports HBR audio up to 1536kHz |
Note: The output resolution, refresh rate, video pixel format depends on the performance of the computer and the monitor |
• 2x USB Type-A Female |
1- USB Type-A port (next to HDMIHDMI™ port) supports max 7.5W([email protected]) downstream charging |
2- USB Type-A, second port support max 4.5W(5V@900mA) downstream charging |
Max 5Gbps bandwidth per USB Type-A port |
• RJ45 (Gigabit Ethernet) |
-Support 10Mbps/100Mbps/1000Mbps |
• USB Type-C Data Female(Close to USB-A port) |
- Max 5Gbps data transmission |
- Support 4.5W(5V@900mA) downstream charging |
- Support short-circuit, over-current, over-voltage protection |
• USB Type-C Female (for PD 3.0 Charging) |
- Support PD Charging 100W (15W is dedicated to the functioning of this product, the rest power(max 85W) will be passed to charge for the host |
- Support Fast Role Swap of PD 3.0, the connected device will not get disconnected while plugging in and out PD Adapter |
• Windows and OSX |
• CSV-1596 USB Gen1 Type-C, 6-in-1 Hub with HDMI™8K30Hz-4K120Hz, 2xUSB Type-A, RJ45 and 2xUSB Type-C, Data and PD charging 100 watt |
Available Interfaces |
• 1x USB Type-C Male |
(Host connection) |
• 1x HDMI™ Female |
for connecting to Monitor |
• 1x USB Type-A Female |
Data |
Charging/Data |
• 1x USB Type-C Female |
Data only |
PD Charging only |
• 1x RJ45 Jack |
• Box size 7 x 32 x 3.5cm / 2.76 x 12.6 x 1.38" |
• Device size: 12.6 x 3.4 x 1.4 cm / 4.96 x 1.33 x 0.55" |
• Total Length: approx. 30 cm /11.81" |
• Device Weight: 89 gr / 3.14 oz |
• LDPE Bag Weight: 5gr / 0.17 oz |
• Box Weight: 42 gr / 1.48 oz |
• Total Weight: 136 gr / 4.79 oz |
Note: - Please update your TV Firmware to the version which supports these resolutions/refresh rates ! - Please update your Graphic drivers on your PC and make sure that DSC1.2 is supported on your devices to support the these resolutions/refresh rates! |
- CSV-1596_SPECIFICATION-SHEET_EN.pdf
- CSV-1596_SPECIFICATION-SHEET_DE.pdf
- CSV-1596_SPECIFICATION-SHEET_ES.pdf
- CSV-1596-QUICK INSTALL-GUIDE_EN.pdf
- CSV-1596-QUICK INSTALL-GUIDE_DE.pdf
- CSV-1596-QUICK INSTALL-GUIDE_ES.pdf
- CSV-1596-BOX-3D_HR.zip
- CSV-1596-QUICK INSTALL-GUIDE_EN.pdf.zip
- CSV-1596-QUICK INSTALL-GUIDE_DE.pdf.zip
- CSV-1596-QUICK INSTALL-GUIDE_ES.pdf.zip
