Travel Charger 132W GAN technology, Four port USB Type-A and -C, Power Delivery(PD) 3.0 Support
The Club 3D CAC-1906 Travel Charger 132W GAN technology, Four port USB Type-A and -C, Power Delivery(PD) 3.0 Support. This product is a high-performance, low weight travel charger with a maximum output power of 132W. Equipped with 3 USB Type-C ports and 1 Type-A port, the total output supports up to 132W, which can meet the needs of charging four devices at the same time. Compatible with multiple devices (support mobile phones,tablets and laptops). It is a convenient companion during travel and for business! Compact size & Superior Performance: GAN technology makes this charger 50% smaller than a 132W MacBook charger, small enough to carry anywhere.The 132W wall charger match a variety of PD devices from smart phones to laptops, one for all making charging simple. The Power Charger is light weight without compromising on Quality and safety. By adopting Power Delivery(PD) charging technology, this versatile Power Charger provides you with charging function through USB Type-C interface, you can charge any connected Mobilephone / Tablet / NoteBook.
Charging:
By adopting PD 3.0 Charging technology and charging function through USBType-C interface the Club 3D Power Charger offers versatile and unique functionality. It will charge your devices up to 132Watts. Built-in safeguards protect your devices against excessive current, overcharging and overheating.
Product Name: |
Travel Charger 132W GAN technology, Four port USB Type-A and -C, Power Delivery(PD) 3.0 Support |
Product Code: CAC-1906 |
EAN code: 8719214472276 |
UPC code: 841615102518 |
• Internal chip allows an input voltage of 100-240VAC 50/60Hz |
• GAN technology |
• 132W of output power in total: |
Output Single Port |
C1: PD 5V3A;9V3A;15V3A;20V/5A(100W) |
C2: PD 5V3A;9V3A;15V3A;20V/5A(100W) |
C3: PD 5V3A;9V2.22A (20W) |
USB-A: 5V2.4A(12W) |
Output Four Ports |
C1+C2: PD 50W(PD:5V3A,9V3A,20V2.5A) |
C3: PD 20W(5V3A;9V2.22A) |
• Power Delivery(PD) 3.0Support |
• Accurate limited current output and over current protection. |
• Overload protection and over voltage protection. |
• Short circuit protection. |
• Over temperature protection and remove the fault conditon auto-recovery. |
• Compliant with CE, FCC standards. |
• Ligth weigth and convenient to use. |
• Specially designed for your USB Type -A and Type-C supported devices. |
• All |
• CAC-1906 Travel Charger 132W GAN technology, Single port USB Type-C, Power Delivery(PD) 3.0 Support |
• 1x RED (Power ONLY)USB Type-C cable(1 m / 3.28 ft) for connecting to Host |
• 1x Powercord depending on Country (Specify on order) |
Available Interfaces |
• 3x USB Type-C Female |
• 1x USB Type-A Female |
• Box size: 17.5 x 17.5 x 4.5cm / 6.89 x 6.89 x 1.77" |
• Device size: 10.9 x 8.6 x 3.2 cm / 4.29 x 3.38" |
• Device Weight: 487 gr / 17.18 oz |
• USB Cable Weight: 35 gr / 1.2 oz |
• Box Weight: 63 gr / 2.22 oz |
• LDPE Bag Weight: 9 gr / 0.35 oz |
• Total Weight(depending on PowerPlug) approx.: 594 gr / 20.95 oz |
Warning Safe Usage: Only to be used at altitude 2000 meters/6562 feet and below. |
- CAC-1906_SPECIFICATION-SHEET_EN.pdf
- CAC-1906_SPECIFICATION-SHEET_DE.pdf
- CAC-1906_SPECIFICATION-SHEET_ES.pdf
